Synth Freq. — Parallax Forums
Synth Freq.
gambrinogambrino Posts: 28
edited 2008-11-10 14:38 in Propeller 1
Hello , i would like to ask if someone changed the code in the library Synth.Spin (which is in Spin language) , to propeller assembly language .
Is it possible or it's very complicated ?
Thank you in advance
Post Edited (gambrino) : 11/9/2008 5:37:41 PM GMT
  • Beau SchwabeBeau Schwabe Posts: 6,568
    edited 2008-11-10 06:26
    gambrino,
    It's possible... the main reason I didn't do it was because I didn't want to mess with Assembly division at the time. That said you can pre-calculate the values with Spin, and just pass them into Assembly. The same registers exist in Assembly as do in Spin. Just use the MOV command to set the CTR's, FRQ's, and DIR's from within Assembly.
    Beau Schwabe
    IC Layout Engineer
    edited 2008-11-10 14:25
    Since the initial question has been answered, may I ask if anyone has done any
    calculations on musical note-to-frequencies using Synth? I'd love to have this list
    if someone has done it.
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Got an SD card connected? - PropDOS
  • LeonLeon Posts: 7,620
    edited 2008-11-10 14:29
    Do you mean a note-to-frequency table? There should be plenty of those on the Web, or you could generate one in Excel. I used one many years ago to play simple tunes on a Z80.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Duh, I didn't think about this not being "Synth" specific! Thanks for hitting me in the head. [noparse]:)[/noparse]
    OBC
