Counting frequencies.
EDIT: I get a difference of almost 20% between the code in Experiment #17 and Experiment #18. Can anyone tell me why?
This is very slightly modified code, right out of Stampworks Experiment #18. Unmodified it works fine to display
100 Hz or
10 Hz or
1 Hz.
Problem is, I want to see more (100.nnn Hz). So I made this modification:
' This program monitors and displays the frequency of a signal on Pin 0.
' I/O Definitions
FreqPin CON 0 ' frequency input pin
' Constants
Convert CON $0200 ' input to uSeconds (BS2)
' Convert CON $00CC ' BS2sx
' Convert CON $00C0 ' BS2p
' Variables
pHigh VAR Word ' high pulse width
pLow VAR Word ' low pulse width
period VAR Word ' cycle time (high + low)
freqH VAR Word ' frequency
freqL VAR Word ' frequency
' Program Code
Main:
PULSIN FreqPin, 0, pHigh ' get high portion of input
PULSIN FreqPin, 1, pLow ' get low portion of input
period = (pHigh + pLow) */ Convert ' calculate cycle width in uSecs
freqH = 50000 / period * 10 ' calculate frequency
freqL = 50000 // period * 10 ' calculate frequency
' display on DEBUG screen
DEBUG HOME
DEBUG "Period...... ", DEC period, " uS ", CR
DEBUG "Frequency... ", DEC freqH , ".", DEC freqL, " Hz "
PAUSE 200
GOTO Main ' do it again
END
When I check the result against a calculator, it looks close but not spot on. Is this the correct way to do this?
Post Edited (Steve in NM) : 11/9/2008 5:21:17 PM GMT
100 Hz or
10 Hz or
1 Hz.
' I/O Definitions
' Constants
' Variables
' Program Code
Main:
DEBUG HOME
PAUSE 200
END
