Connecting a Propeller to Embedded blue 500
I could use some recommendations on the simplest way to connect these devices.
Prop inputs can use a series resistor ? - TX and Status pins
Can propeller outputs drive the embedded blue inputs without a translator chip? Rx and Mode pins
Are RTS and CTS typical used? Are they input or output?
Any advice would be appreciated
Paul Baker
Great Project, well worth the effort.
I only used resistors on the input lines to the propeller though!
