Gosub to a variable ? — Parallax Forums
Don MooreDon Moore Posts: 4
edited 2008-11-09 07:28 in BASIC Stamp
I'm very new to programming in for the BS2 and have run into a problem. I'm trying to use the GOSUB command but instead of an "address label" I'm trying to get it to read the value of a variable as the address label, and I'm getting an error. "Expected a label"
I'm trying to use it to look up a value to draw with a 7 LED display POV wheel.
I know there's an easier way to do it but the concept is below:
If I can't do it this way, is there a way to pipe my LOOKUP output into the GOSUB command directly instead of a variable (like is done with the OUTH after the lookup for a 7-seg LED)?
Thank you in advance.
~Don
displaychar        VAR      Byte                ' Letter to be drawn
DO
FOR counter = 0 TO 6
    LOOKUP counter, [noparse][[/noparse] "A", "B", "C", "D", "E", "F", "G" ], displaychar       ' I'm just using this as test data.  Later it will be READ from a DATA string, which I'll want to be able to edit for various messages.
    GOSUB [color=#990000][b]displaychar[/b][/color]
    PAUSE 10
NEXT
LOOP
A:
OUTH = %0011111
OUTH = %0100100
OUTH = %1000100
OUTH = %0100100
OUTH = %0011111
RETURN
G:
OUTH = %0111110
OUTH = %1000001
OUTH = %1001001
OUTH = %1001001
OUTH = %0111010
RETURN
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2008-11-09 05:40
    Don Moore,
    Check out the ON... GOSUB function...
    Syntax: ON Offset GOTO Address1, Address2, ...AddressN
    Beau Schwabe
    IC Layout Engineer
  • Carl HayesCarl Hayes Posts: 841
    edited 2008-11-09 05:52
    No; you can't do that. A variable is not executable code. Whatever you GOSUB to must be executable code. It's as if you were trying to follow a recipe for Beef Stroganoff, and when you got to page 2, which should contain instructions, instead of paper with additional instructions on it you found a little pan of tangerine Jelly Bellies. Your cuisine would suffer.
    Whatever you GOSUB to should be a section of code that eventually executes a RETURN instruction to continue just after your original GOSUB.
    GOSUB is like a little side trip for your program. Your program uses GOSUB to take a little side trip, then returns to where it left off, to continue the main journey.
    · -- Carl, nn5i
    edited 2008-11-09 05:59
    Don Moore,
    Change your FOR/NEXT loop to look like this....
           ON counter GOSUB A, B, C, D, E, F, G
           PAUSE 10
    NEXT
    Beau Schwabe
    IC Layout Engineer
  • Don MooreDon Moore Posts: 4
    edited 2008-11-09 06:10
    CARL:
    I understand that.. but what I'm trying to do is something to the sort of...
    MyMessage DATA "This message will be displayed 0" <<--- I want to be able to change this without reworking the entire program
    index VAR byte
    DO UNTIL displaychar = 0
    READ MyMessage + index, displaychar
    Gosub displaychar
    index = index + 1
    loop
    And I'm using GOSUB because I may have to jump to the letter E for example several times for my message...
    I didn't want to have to hardcode a bunch of GOSUB <address> manually every time I changed the displayed message.
    BEAU:
    Using the earlier suggestion, I could do a LOOKDOWN on the read "displaychar" to get an offset value (0-25 for A-Z) to use, then specify that on the {ON offset GOTO address1, address2....}. I just thought there might be a more direct approach.
    I'll give it a shot to see what I can come up with.
    Your new approach will work but it won't allow me to do content checking .. for example .. if the character is a "space" pause for 20ms instead of a GOSUB command. The ABCDE text is just something for me to get started with then build off of
    I think I'll have to do your earlier suggestion. The second suggestion you made however, is interesting, and gives me a few ideas for later.
    Thanks again.
    Post Edited (Don Moore) : 11/9/2008 6:16:10 AM GMT
    Why not parameterize your code entirely, so you don't need separate subroutines? viz:
    Ltr_A DATA %0011111, %0100100, %1000100, %0100100, %0011111
    Ltr_G DATA %0111110, %1000001, %1001001. %1001001, %0111010
    FOR counter = 0 to 6
      ptr = counter * 5 + Ltr_A
      FOR i = ptr TO ptr + 4
        READ i, char
        OUTH = char
      NEXT
      PAUSE 10
    NEXT
    Your program will be more compact this way, as well.
