Basic Samp 2 OEM - Cannot communicate
Someome gave me a Stamp 2 OEM kit.· I build it as shown.· When I run the Identify command from the IDE, it does not find anything.· I checked the power on the Vss and Vdd pins on the PIC chip on the board, and it is showing +5V correctly.· I tested the serial cable by connecting a modem to it and it seems to function.· So I either
made a mistake in construction, or have a bad kit.· Any other steps to debug?· I have a scope also.· Is there a clock out output to check or some other diagnostic on the PIC chip to check.
Thanks!
Thanks!
on a scope, and there is a nice Sine wave. I also ran a serial port analyzer, and see this:
Port opened by process "Stampw.exe" (PID: 1424)
00 42 00 65 00 58 00 50 00 49 00 54 .B.e.X.P.I.T
Port closed
· -- Carl, nn5i
- Are you connecting to a real serial port or are you using a USB to Serial Converter?
- Are you using the latest BASIC Stamp programming software?
- When you try to identify the OEM Stamp does anything come back? Device type, Version, Loopback, or Echo?
Of you look at the schematic for the BS2p40 or BS2SX modules they usually show the serial connection on the bottom of the page. Is that what you are connecting to the serial cable? It has a jumper for the loop back (not always needed) and a couple of caps which are used to reset the Stamp for programming.
* Real serial port
* Basic Stamp Editor V2.3.9.
* Loopback and Echo = Y, Device Type and Version = blank
* I am connecting to the DB9 connector that was soldered onto the OEM board. There are no other connectors on the board.
Thanks!
You are getting the echo because of R1 across the RX and TX lines which is normal. Since you are getting that and the loop back that is a good sign.
Was this a pre-assembled module or kit built? Q3 is supposed to be a 2n3906 and if it is mixed up with one of the other two it won't work. I would double check everything to make sure all the parts are in the right place. Also look for solder bridges or cold solder joints and clean up any that look questionable.
Robert
The manual clearly states that the pins should be pre-formed before insertin into the PCB for Q1,Q2,Q3,and U3....But like Myself ; This part Is'nt read untill It does'nt work,And then We read "that" part of the manual........Details...Details...Details...
________________________$WMc%________________________________Details________
