Position Controller and HB-25 refresh
Hello All,
When using the Parallax wheel kit and the HB-25 together, will the position controller allow the HB-25 to timeout on a long run? To clarify I'm considering running the HB-25 in the mode where a pulse is required at least every 4 seconds to keep the motor running. If I command the position controller to move a long way at slow speed will it refresh the pulses often enough to keep the motor going? I didn't see anything in the docs on the position controller one way or the other.
The idea is to use the lack of pulses to the HB-25 as an "uh-oh" signal and allow the HB-25 to timeout as a response.
Your thoughts are appreciated.
Greg
Greg
I am asking about the pulses that the position controller will send, not the response of the HB-25. The section you pointed me to describes the timeout feature which I understand and want to use. For example, if I command the motor to travel a distance that will require a 10 second run, will the controller send its programmed full speed pulse to the HB-25 and then wait until the desired position is reached before sending another (allowing the HB-25 to timeout because it hasn't received a pulse in 4 seconds)? Or will it periodically be refreshing the full speed command as it is traveling? It seems like my answer should be in the motor controller docs, not the HB-25 docs.
I am willing to bet that Parallax thought of this already, but I wanted to confirm.
Thanks for your help.
Greg
To answer your question, Position Controllers generate a continuous stream of pulses all the time - whether or not the pulses are changing value or staying the same. Upon power-up it begins generating the pulses (even before it receives a command to move), and continues to generate a new pulse every 20 ms.
Hope this clears up your question
-Kevin
Thanks.
Greg
