aux i/o pins on BS2p40
howdy!
can someone direct me to instructions on how to access the aux pins on a BS2p40?
for example if I want to read a switch on pin 0 I type:
debug home, ? IN0
but what if I want to read a switch on the pin labeled as X0 on the BS2p40SchematicRevD downloaded from parallax?
i tried both:
debug home, ? INXO
and:
debug home, ? IN21
Im sure its something simple Im missing
thanks
debug home, ? IN0
i tried both:
debug home, ? INXO
and:
debug home, ? IN21
thanks
But since you asked, pins on the AUXIO side are accessed *as if* they were also numbered 0-15, but you must "choose" which side you are working with at any given time using the AUXIO and MAINIO commands (IOTERM is cool also for more programmed switches).
i.e.
One note, that in my experience, while slot switches (i.e. RUN x) are fast, pin bank switches are *relatively* slow -- so if you pile them up you will see precious milliseconds start to vaporize. I try to set up my programs so that all the MAINIO work gets done, then all the AUXIO work, so that there are few switches back and forth.
