Prop to Prop wireless based on hydra example?
Hello All,
I may just way over my head here, but wireless is not my strong point. So I was thinking a few have done some things receiving specific signals on the prop using counters, propRadio comes to mind. Why cant we change the signal slightly and use the same method of broadcast that the hydra uses. It broadcasts its video signal with little more than an antenna hooked up to a pin. Maybe Im missing part of this, but it seems to me to be a simple idea to make 2 props wireless if the same method could be used to receive a signal. Two antennas to two pins on each prop and bam 2 way communication. I haven't the slightest clue what the speed would be, but would this even be possible? Or has it been done?
It seems fairly simple, but ive said that before to have it bite me hard.
So what do you all think, possible? Built in prop RF comm?
TJ
TJ
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Transmitting RF is certainly possible with the Propeller, the issue comes at receiving, not entirely impossible but it's far from trivial.
Paul Baker
