I'm not sure how you are going to get fuel economy from those inputs.·
I would suggest using the vehicle speed/distance traveled, injection duration and engine RPM.· You could find the amount of fuel dispensed by the injectors from the factory repair manuals.
1%,is the ASM,ASTM,etc.,Standard for Accur...I'm sure You know this already,,,well done on the project....Are You useing a $stamp in this App????, If So would You mind Shareing some of Your code/hardware w/ Us.....Shareing Code/Hardware help's Us all.,,It reduce's the redundantsy of every user doing the same Expeir.,,usually to come up w/ the same results.....
www.emesystems.com/BS2index.htm#math
Tracy Allen explains how to do the kind of math you'll need using a BS2.
Daryl
_______________________________________$WMc%___________________________________
