Can the Proellor handle Negative volts??
krazyideas
Hello
I am wanting to use the CTRA mode %11010 to measure a pulse from a light show that goes +5 volts -5 volts and I want to know if I can plug that stright into the propellor board or if I need to bring the volts down??· I know that anything above 1.6 volts it reads as high and anything below that it reads low, and that the propellor puts out·3.3 volts when a pin goes high.· But will it hurt it if it is fead +5 volts to read as high and -5 volts to read as low as the input for CounterA to read????
Also kinda a dumb question but what does the % infront of the mode you set for the logics do, like in %11010.
Anyway thanks so much
2) You can potentially damage the Propeller chip if you connect a negative voltage to an I/O pin without some kind of current limiting resistor.· Similarly, you can damage the chip if you connect a positive voltage greater than 3.3V without some kind of current limiting resistor.· For voltages like +5V or -5V, a 1K resistor is adequate, but something more like 10K is better.· Use Ohm's law to see how much current is involved.
Here is a resistor divider circuit that will convert (5V...0V...-5V) to (3.35V...1.65V...-55mV)
Beau Schwabe
IC Layout Engineer
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 11/5/2008 1:35:52 PM GMT
That works if the Bi-Polar input is 5V and Vcc is 3.3V, the Uni-Polar output is 3.32V.· However·if the Bi-Polar input is·negative 5V and Vcc is 3.3V then the Uni-Polar output will be·negative 1.68V
Beau Schwabe
IC Layout Engineer
Leon
Leon
Tracy Allen
www.emesystems.com
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
