RF Communication between 2 BS2's
Hello. I was just wondering how I would go about transmitting data between 2 BS2's using this transmitter and reciever?
This is the data dor the transmitter:
Operating Voltage: dc 3-12V
Current: 5-45 mA
Modulation: AM
Frequency: standard=315
Range: 1000m
Pins: VDD, TXD, GND, ANT.
This is the data for the reciever:
Operating Voltage: dc 3-8V
Modulation: AM
Frequancy: 100 - 500. Standard=315/433
Sensitivity: -103 dbm
Transfer rate 4.8K pbs
Output: TTL
Pins: VDD, RXD, GND, ANT.
Any and all advice will be greatly appreciated. Thanks
Post Edited (Aidanx1) : 11/5/2008 12:56:56 AM GMT
Current: 5-45 mA
Modulation: AM
Range: 1000m
Modulation: AM
Output: TTL
Note that your modules are rated only up to 4800 Baud while the sample code assumes 9600 Baud.· You'll need to change the Baud constants in the SERIN and SEROUT statements.· There's a table in the PBasic Manual that gives the Baud constants for various Bauds (in the chapters on SERIN and SEROUT).· Consult that.
Post Edited (Mike Green) : 11/5/2008 1:10:01 AM GMT
· -- Carl, nn5i
Carl, I'm in the UK so the FCC doesn't effect me. However there are probably some similar laws in the UK but it's only a low power transmitter with a 1000m range (probably less). I don't think it will interfere with much, especially since it is only 315Mhz.
www.ofcom.org.uk/
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
