Possibility of using prop for a 216-220 Mhz Beacon
Ok, I'm a bit lacking on transmitter knowledge, so I thought I would ask.
Could the propeller be used to transmit a repeating pulse on a frequency of 216-220 Mhz?
I would like to hear the ideas, and information about possible drift.
James L
Edited title for mis-spelled words
James L
Partner/Designer
Lil Brother SMT Assembly Services
Post Edited (James Long) : 11/4/2008 12:29:52 AM GMT
James L
James L
Partner/Designer
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
The cog counters can produce an output up to about 128MHz which could be doubled to the 216-220MHz range, but the output would have a lot of noise and would need a lot of cleaning up. The high frequency (and the frequency multiplication) also multiplies any drift.
The Propeller's oscillator is not designed for any kind of temperature stability. Crystals drift with temperature changes, with changes in capacitive load. There would be changes with any shift in power supply voltage, etc.
You would be much better off using an external oscillator designed for that frequency range and using the Propeller just to gate it on and off.
Leon,
This was being designed as a part 15 compliant device, and it would need to be tested for certification.
James L
James L
Partner/Designer
Thanks for the info Mike, I didn't think the accuracy of the propeller would do in this situation.
I wonder if I could tune it down into the FM range....and keep the cost down. Would still need an external oscillator to prevent major drift.
James L
James L
Partner/Designer
Leon
Post Edited (Leon) : 11/3/2008 7:45:15 PM GMT
I agree, the Prop is way overkill for this project, but this is only a possible part of the project, the other parts have been designed, and are actually independent.
James L
James L
Partner/Designer
