Serial interface
I have set up a Propeller to serial port circuit as seen in
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/SerialtoPropeller.pdf
I then connect the serial plug to a Radioshack 26-183 USB to serial cable.· When I search for the propeller chip using the Propeller Tool V1.2, it cannot identify the presence of the propeller chip.· It does, however recognize the Radioshack USB to Serial cable.· I have the Radioshack USB to Serial cable settings as follows:
Bps:· 9600
Data bits:· 8
Parity:· None
Stop bits:· 1
Flow control:· None
Any thoughts about what I might be doing wrong?
Thanks.
Bps:· 9600
Data bits:· 8
Parity:· None
Stop bits:· 1
Flow control:· None
Thanks.
you must register and then download
our tutorials on chip FT232,
we designed and built a module to be mounted
in any circuit that requires the conversion USB/232:
Introduzione al convertitore USB <-> RS232 FT232BM (introduction to USB converter)
http://www.elettronicamente.com/engine/default.asp?page=projectdownload&pid=333
Interfaccia convertitore USB <-> RS232 (Rev.2) (USB converter),
http://www.elettronicamente.com/engine/default.asp?page=projectview&pid=338
Il modulo ELFT232-M (the module ELFT232-M)
http://www.elettronicamente.com/engine/default.asp?page=projectdownload&pid=334
Costruzione del modulo ELFT232-M (how made the ELFT232-M module)
http://www.elettronicamente.com/engine/default.asp?page=projectdownload&pid=458
The interface·is USB/TTL 5 volts, we must adapt the signal at 3.3 volts)
Bye
Fisio
Post Edited (fisio) : 11/2/2008 11:05:12 PM GMT
