BS2 & Piezo Speaker — Parallax Forums
BS2 & Piezo Speaker
HumanoidoHumanoido Posts: 5,770
edited 2008-11-04 18:34 in BASIC Stamp
Looking for some VERY SIMPLE ways to increase the
volume of a piezo speaker on a BS2 HomeWork
Board...
    edited 2008-11-01 13:14
    "...VERY SIMPLE..."
    How about a paper cone, the old Victrola effect?
    Post Edit -- Works great with a funnel.
    Post Edited (PJ Allen) : 11/1/2008 5:40:16 PM GMT
  • MikerocontrollerMikerocontroller Posts: 310
    edited 2008-11-01 22:27
    · humanoido, have you seen the resonator used on the SoundPal?· Maybe a section of thick shrink tubing?
  • Carl HayesCarl Hayes Posts: 841
    edited 2008-11-01 23:43
    A simple cone would be surprisingly good. Even better would be a cone shaped like the bell of a trumpet, but of course smaller. With the right shape you can transfer much more energy into the air from that tiny transducer. Edison mechanical phonographs had diaphragms not much larger than the one in the little piezo speakers, yet with the big flower-shaped cones they were easy to hear. Unless, of course, you're ancient like me, and have trouble detecting freight trains ten feet away.
    · -- Carl, nn5i
    edited 2008-11-01 23:45
    Come to think, you could get a tiny plastic toy instrument and cut off the cone.· I may try that myself.
    · -- Carl, nn5i
    edited 2008-11-02 00:04
    That was in the back of my mind about a tiny cone.
    Per suggestion, I tried it. Took a yellow 3M Post-It Note,
    folded into a cone shape and slipped it over the piezo speaker.
    Gadzukes!!! It appears to have doubled or tripled the volume!!!
    Another great idea about using the heat shrink tubing...
    I looked through about 20 different sizes in the storage bin,
    but none were large enough to go over the piezo speaker's
    diameter. Then I remembered, I bought a Chinese washer
    drain hose to use as strain relief for robot servo cables.
    I cut off a small cylinder piece and place it over the piezo.
    There were two pieces. One from the end which had smooth
    walls, and one from the corrugated section. I expected the
    smooth would work better.
    The results are in. The smooth and corrugated sections work
    the same with no noticeable difference. Comparing the
    cylinders to the cone, performance is nearly the same, with
    the cone taking 1st place for best overall frequency range
    resonance. The tiny cone can reproduce lower frequency
    with richer sounds.
    It's much more convenient to slip on little cut pieces of
    cylinder than to fold up paper cones. The frequency response
    favors the upper end sound spectrum where higher pitches
    have excellent volume.
    My next question - does the length of the cylinder or size of
    the cone matter? If the cone or cylinder is made larger and
    larger, at what point is the sound maxed out?
    Any guesses??? [noparse]:)[/noparse]
  • SRLMSRLM Posts: 5,045
    edited 2008-11-02 02:08
    A 5000 Hz sound wave has a wavelength of about 2.7 in, so that's probably why the corrugated and smooth worked the same.
    For making it longer, you'll probably have to guess. I'd assume that each bounce of the wave on the wall takes out a little bit more energy from the wave, until it just dies. If I had to pick a number, I'd say a length of 1.35 in would be ideal, but I don't really have any idea at all.
  • MovieMakerMovieMaker Posts: 502
    edited 2008-11-02 02:13
    do you have any pix? I would like to see, if it is possible.
    edited 2008-11-02 14:24
    Ideally the sound waves don't bounce off the walls of the cone anyway.
    For an excellent treatment of cones, or horns,·used for coupling speakers to air, go to the library and see if they have the·Radiotron Designer's Handbook, Langford-Smith,·circa 1953.· This was published in the USA by Radio Corporation of America.· It's a very fat (3 in)·red book with an incredible wealth of information.· Start on page 851, "Horn Loudspeakers".
    · -- Carl, nn5i
    edited 2008-11-03 01:54
    Here's the pic showing an experiment with
    a half side open directional speaker cone.
    In the background you can see the tubing
    which also works well.
    286 x 209 - 9K
    edited 2008-11-03 02:54
    Transistor amp. The BS2 HW board has 220 ohm resistors inline on all the IO pins, which:
    a) limit how much current can flow (bad), and
    b) are perfect to bias a 2N2222 transistor amplifier (good)
    I know this provides a dramatic volume increase on a paper speaker (mit kapazitor, jah?) and it should help a piezo speaker, too.
    edited 2008-11-04 07:25
    erco, got a simple schematic? I'll build it.
    Should have some 2n2222's just
    waiting to try it out.
  • Beau SchwabeBeau Schwabe Posts: 6,570
    edited 2008-11-04 15:23
    This topic comes up every now and then... "I want a louder piezo" ...If you understand what the piezo crystal is doing and how it behaves, there are certain things you can do to exploit the behavior of a piezo.
    Reference page:
    http://forums.parallax.com/showthread.php?p=464410
    Low power Piezo inverter driver schematic:
    http://forums.parallax.com/attachment.php?attachmentid=36227
    Beau Schwabe
    IC Layout Engineer
    edited 2008-11-04 17:26
    Looks like Beau beat me in timeliness and technology! His piezo solution is definitely·better, driving the piezo crystal·in both directions. My simple approach is below, just using one transistor. It is probably more effective on a traditional paper cone speaker since it lets more current flow, but it may yield improvement on a piezo speaker as well. Keep in mind, my drawing shows a 220 ohm resistor (built into each of the HW board's 16 pins) so don't add that to a HW board. Only add it to a discrete Stamp or BOE.
    Using the same schematic below,·you can·also attach your piezo's positive lead to +9 volts instead of +5 volts for more voltage & volume.
    BTW, the resonant frequency of your speaker is a huge factor, per Beau's excellent links.
    225 x 250 - 7K
    Another simple solution is an audio line transformer. I have the Xicon ultra-mini, 600 ohm to 100 ohm, with the 100 ohm side to the Stamp or sx or prop, and the 600 ohm side to the piezo. (Mouser 42TL031-RC) It can be used in combination with push-pull drive that Beau suggested. Note that if you are doing this with an sx chip or a prop, you can get the push pull drive by connecting between two output pins, driven 180 out of phase.
    I use this with ultrasonic piezos. The transformer is not rated for 40khz, but it does in fact work happily there.
    Tracy Allen
    www.emesystems.com
