PCB pins — Parallax Forums
PCB pins
Paul MPaul M Posts: 95
edited 2008-11-01 20:31 in General Discussion
Does anyone know what the edge mounted PCB pins are called that are used for example on the Basic Stamp modules. Are they available from any of the usual suppliers in the UK· - RS, Farnell,·Rapid?
Thanks in advance
Paul··
    edited 2008-10-31 20:38
    They are a boutique component and are only availible on giant reels that we have to special order (from France IIRC).
    Paul Baker
  • Paul MPaul M Posts: 95
    edited 2008-10-31 21:26
    Thanks Paul
    I feared as much. The reason for asking was that I want to replace another 40 pin DIP uC (which shall remain nameless) with a LQFP propeller based adaptor board - I can still do it with turned pin headers but it won't look as good.
    Post Edited (Paul M) : 10/31/2008 9:31:19 PM GMT
    edited 2008-10-31 21:33
    A couple times we have snipped a small portion off and mailed it to a customer (they are delicate and frequently get bent during shipping), but with you living in the UK, I think the shipping costs wouldn't make it worth your while.
    Paul Baker
    edited 2008-11-01 12:30
    Thanks for the offer Paul. I will make some more enquiries·and may come back to you in the future.
  • LeonLeon Posts: 7,620
    edited 2008-11-01 13:25
    I use SIL turned pins if I need to make a plug-in module. The PCB has to be a bit bigger, of course.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Leon
    Yes that is how I would do it and yes·it has to be bigger and really doesn't look as good (professional) in a commercial product. My main regret is that I had not discovered the prop when I produced the units that need the uC replacing..........
