Debug Watch with Bit indexing
I have been trying to understand why I cannot get the Watch directive to show bit indexes of variables.· The Watch register just shows "0".
Here is SX/B sample code to·load a var "i" with 127 (byte).· Then I want to look at each bit in Byte I using the Watch directive in the debugger....
device·sx28, osc4mhz, turbo, stackx, optionx
freq·4_000_000
i·var byte
program start
Start:
·i=127
·watch i,8,ubin
·watch i.0,1,ubin
·watch i.1,1,ubin
·watch i.2,1,ubin·
goto start
What I see in the debug Watch register is ...
i······· %0111_1111
i.0····· %1
i.1····· %0
i.2····· %0
As can be seen the i variable is loaded correctly with the value 127 (Dec).·
Why does i.0 work and the others i.1 and i.2 not work?
What am I doing wrong?
System:····· DELL XP Desktop
SXKey IDE:· v3.2.92h BETA
SX Key:······ Rev F
SX Chip:····· SX28AC/dp·· Date code: AB9932AB
Interface:·····Serial RS232
Any advice would be appreciated.
Brian
freq·4_000_000
i·var byte
program start
Start:
·i=127
·watch i,8,ubin
·watch i.0,1,ubin
·watch i.1,1,ubin
·watch i.2,1,ubin·
goto start
i······· %0111_1111
i.0····· %1
i.1····· %0
i.2····· %0
SX Key:······ Rev F
Brian
This is a bug in the SX-Key IDE. It has been brought up several times.
It also affects SX/B bit variables. Unless they are in bit position 0, they don't change in the watch window.
Bean.
"The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
www.iElectronicDesigns.com
I did find out that if I assign a bit to another variable (i.e., a = i.3) and then "Watch" that new variable (i.e., a), I can make it work for the time being.··... but it wastes valuable RAM space.·· I can always look at the full byte as a partial solution too.
Thanks again....
Brian
