Ubuntu 8.10
Just wondering if anybody has tried the new version of Ubuntu, and what Parallax software can now be run on it? I am interested in running the SX, and Propeller stuff on Ubuntu, hopefully without to much trouble. I ran the live 64 bit version on my laptop, and it seemed to function OK. I am hoping that some of the experts here will discuss whether the new version is now better suited to run the Parallax software.
Ray
Ray
Did you get the Parallax SX software to work on Ubuntu ?
I would love to get back to SX/B but when I start up the SX IDE in Wine, no serial ports are found...
Any pointers ?
For the Propeller I use BST (Brads Spin tool), works great...
http://forums.parallax.com/forums/default.aspx?f=25&p=1&m=298620
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Ray
Since I could not find the ports, no other testing was done...
I run XP in VMWare, it's slower than running natively, on the other hand, the Parallel port now works with my EPROM programmer...
Experience level:
/Bamse
www.virtualbox.org/
It runs all of the MS Windows software I've tried including the Propeller IDE. It wasn't that hard to setup for me but it may be a challenge if yo don't have much computer experience.
Also you still need to own a copy of a Windows operation system and install it on the VM
Aka: CosmicBob
Now, if somebody came up with a similar solution for SX IDE, I think I would say goodbye to Windows.
In the process of using Linus, I did install WINE in both Fedora and Ubuntu and tested it with all the Parallax IDEs. It works fine for editing and study, but Linux has an entirely different approach to serial ports and the actual programing of the BasicStamp, the Propeller, or the SXes require transfering a copy of the program to a Windows machine.·
There is one 'compiler' that will prepare BasicStamp software for programming in Linux, but it is a second program -- not a full IDE. This is a more traditional approach. Some may say it is less user friendly, but it just a different way.
WINE did have one buggy screen feature that appears to be an incentive to purchase Crossover Linux, the commercial counter part. I tried Crossover Linux and it was seamless, but again without the serial or USB interface needed for programing.
I finally decided to have a dual boot system that has Windows for the occasional need to use Parallax software and have done most of my· computing in Ubuntu which has been great. I think that anyone that really wants to learn computing needs to at least explore Linux as there is a lot of free support and software that will help you advance more quickly. But, there will always be somethings that are available only in Windows. Parallax is very helpful, but their customer base in mainly beginners that are part of the 90% of the world that uses Windows.
At this point, I have a new 64bit Core2 Quad with Vista and I am establishing another dual book setup. I am completely sold on Linux as a better overall system for productive work.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
