Code for a Menu
Okay. I have a project that I have been working on for the past few months.
I have the backend working, but I need a Menu system. I have already coded a menu system that works fine, but is messy and large.
I am trying to streamline the code and make it a little more elegant. I am using the Parallax 4x20 character display as well as the
Serial Terminal Debugger on the PC to see where the program is.
I have broken down the menu into separate 5 types:
- Splash Screens (all text, either timed display or press down to continue)
- Menus (Contains all text, but displays an arrow indicating the current selection)
- Choice Menus (Contains choices that when selected, will adjust one value that is displayed)
- Status Screens (Contains values that are displayed from other cogs)
- Tables (Contains a Table of Values that can be adjusted)
The system is controlled with a 4 position button arranged for Up, Down, Left, Right; two buttons for Select and Back; and two more buttons for
Incrementing and Decrementing values.
Basically, I have a method that detects what Menu is being requested which sends it to another method to display the data according to a configuration
table. There are variables to track where the selection is, a method to keep track when an input is made which assigns a value to a variable, to which
the displaying method uses to perform a function (Move Selection Up, Select, Go back one Menu, etc.). I know, when I read it back, it sounds a little confusing,
I am having trouble early on.
The trouble I am having is with the "Menu" MenuType. It seems that when I select one of the options, I move to the next menu. When I go back,
I get the previous menu. But, after doing this two-three times, the program crashes. I have added PST debugging strings that would give me a clue as
to what is happening.
For some reason, the log shows that just before it becomes unresponsive, the program proceeds to go to MenuNumber #12, but ends up displaying #196.
Why would the MenuNumber be a different value to what was assigned to it in the previous line? The code is attached as well as the log file.
Any help is appreciated. If you have any questions on items that I have left out, let me know.
case InputFlag
7:
simple.str(string(">"))
simple.str(string("Current MenuNumber: "))
simple.str(numb.dec(MenuNumber))
simple.tx(13)
MenuNumber := byte[noparse][[/noparse]ConfigAddress]
YPos := byte[noparse][[/noparse]ConfigAddress]
simple.str(string("Going BACK to Menu Number: "))
simple.str(string(", with YPos: "))
simple.str(numb.dec(YPos))
simple.tx(13)
GetBaseAddresses(MenuNumber)
8:
simple.tx(13)
MenuNumber := byte[noparse][[/noparse]@@MenuNumberTable[noparse][[/noparse]MenuNumber+35]][noparse][[/noparse]4+YPos]
YPos := 1
simple.str(string("Going AHEAD to Menu Number: "))
simple.tx(13)
PST doesn't show any of the comments! So the DisplayMethod is not calling the GBA method.
Problem is, I can't see why. Is it too obvious?
When I saved the SPIN file to upload to here, I saved in on my network drive.
Forgetting that I had to save it in my project folder after, I started making the changes that I mentioned below. Each time I tried to write it to the Prop, it was obviously using the one in the project folder, not the one that I was editing.
It now shows the DisplayMenu method calling the GBA method, and displaying the debug comments in it.
I also moved the GetBaseAddresses call from inside the CASE loop, to the last entry of the DisplayMenu method:
case InputFlag 7: simple.str(string(">")) simple.str(string("Current MenuNumber: ")) simple.str(numb.dec(MenuNumber)) simple.tx(13) MenuNumber := byte[noparse][[/noparse]ConfigAddress] YPos := byte[noparse][[/noparse]ConfigAddress] simple.str(string(">")) simple.str(string("Going BACK to Menu Number: ")) simple.str(numb.dec(MenuNumber)) simple.str(string(", with YPos: ")) simple.str(numb.dec(YPos)) simple.tx(13) 8: simple.str(string(">")) simple.str(string("Current MenuNumber: ")) simple.str(numb.dec(MenuNumber)) simple.tx(13) MenuNumber := byte[noparse][[/noparse]ConfigAddress][noparse][[/noparse]4+YPos] YPos := 1 simple.str(string(">")) simple.str(string("Going AHEAD to Menu Number: ")) simple.str(numb.dec(MenuNumber)) simple.str(string(", with YPos: ")) simple.str(numb.dec(YPos)) simple.tx(13) GetBaseAddressesThis seems to have worked, extending the amount of times I can Select and go Back in a menu. However, I still get a crash with the MenuNumber value = 196. Now, I counted the number of times that I can press Select -> Back -> Select -> Back, etc., and noticed that it was 21 times, consistently.
Looks like I have to loop this differently.
I'm willing to help but i don't understand your menusystem and what the problem is.
I guess it has taken you some HOURS or even days to develop this menustructure.
I don't like analysing your menu-picture for hours until I understand it
from the code given it takes a lot of time to analyse what is going on just from READING the code
As I don't have an LCD laying around could you create a version that get's along with one serial connection
to show everything ? Or maybe a version that can use PropTerminal ?
Then all that is needed is a prop and a serial connection
Then everyone can test your program without needing your special hardware
The zipfile you posted seems to be just the display-object but the mainfile that calls the start-method of
the display-object is not included
best regards
Stefan
Let me take a few and try to rewrite the code for the PropTerminal.
It is written for the Stamp, but I have always found it relatively easy to port BS2 code to the Propeller. It could definitely provide some insight to program flow.
Paul Baker
Try to write a universal method for each serial operation, as a subroutine with an input variable acquired from a lookup table. The index of the lookup table would be analogous to the current menu status.
So after reading your post, Sleazy-G, I ran the program piggybacked on the Stack Length code. I found out that every time I press the SELECT or BACK button, I use 10 longs.
Why is that? How do I regain that memory back? I don't understand why it is happening.
Checked with the StackLength code and it seems to not go up over 41. I know that is not a firm number, I will still keep it @ 100, I was only using it to see if I ran out of space.
