Any temperature suggestions? — Parallax Forums
Jim CookJim Cook Posts: 3
edited 2008-10-29 10:49 in BASIC Stamp
I would like to read a temperature of 225 to 275 degrees F and control a 110 voult heater to maintain a temperature set between that range. Naturally, I would like to use the basic stamp and perhaps mounted on the Board of Education. Any suggestions?
  • DufferDuffer Posts: 374
    edited 2008-10-28 23:51
    Have you looked at the Parallax solder pot controller in the "Customer Applications, Industrial" section of the Parallax site?
    http://www.parallax.com/tabid/335/Default.aspx
    And here: http://forums.parallax.com/showthread.php?p=637023
    Duffer
    Post Edited (Duffer) : 10/28/2008 11:58:18 PM GMT
    edited 2008-10-28 23:56
    Air, water/steam, oil? What are you measuring? Can you mount a thermistor or thermocouple on the container, or must it be immersed in the medium?
    You can get an water or oil temperature sender for an automotive application, which will have a resistance proportional to the temperature. You can RCTIME that resistance for a measurement, then have the Stamp switch a relay or SSR to control your heater.
    OR... just use a $1.50 LM339 quad comparator as a controller. Set it & forget it. And save your Stamp for funner things, like robots!
  • Jim CookJim Cook Posts: 3
    Thanks Guys. I'll look into both suggestions.
