There was someone who was working on an emulator for the 8080 processor so the Propeller could run CP/M. You wouldn't be able to run DOS since that would require an 8086/8088 emulator, harder to do than an 8080 emulator.
Post Edited (Mike Green) : 10/28/2008 7:33:22 PM GMT
That's CPM for the 8 bit 8080/8085 architecture with 8 floppy disc drives emulated in SD card. Run all you favourite Microsoft Basic programs, WordStar etc !
Not much support for Prop features at the moment only enough to flash some LEDS.
I'm still tinkering with it from time to time, one day I'll release a version with hard disk emulation and supporting 64K RAM.
@Mike : No I'm not up for the 8086 emulator, it's too much work, would be horrid slow, really needs external RAM (slow) and anyway I realized I've done quite enough programming for that ghastly architecture already.
Although I haven't used anything like this, here's one that came up recently:
http://forums.parallax.com/showthread.php?p=750894
I think you'll find lots of hits if you use this search engine:
http://search.parallax.com/
pgb
An improved version is here: http://forums.parallax.com/showthread.php?p=620700
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
I've got just the thing for you: http://forums.parallax.com/showthread.php?p=711157
