Parallax Servo Controller - help with code
I thought I was reasonable good with code but can not understand the following line of code for the PSC
" SERIN Sdat, Baud, 1000, Init,[noparse][[/noparse]STR Buff\3] "
I thought the call to " Init " is just looping the code within itself.
Unfortunately I have been unable to find any other "user manual or reference material" for the PSC
If any one knows of any it would be appreciated as I think this is a unit with great potential especially if the USB software interface could be turned into loadable code
The following code is from the·Parallax Servo Controller – USB (#28823) Rev B " user manual ???"
RSP Command – Report the Position of a Servo Channel
Syntax: “!SCRSP” x $0D
Reply: x y z(where x is the channel number, and z:y is the value reported)
ch VAR Byte
pw VAR Word
ra VAR Byte
x VAR Byte
Buff VAR Byte(3)
Sdat CON 15
baud CON 396
Init:
ra = 15: ch = 12
DO
pw = 1240: GOSUB WRservo
pw = 240: GOSUB WRservo
LOOP
WRservo:
SEROUT Sdat, Baud+$8000,[noparse][[/noparse]"!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
FOR x = 0 TO 4
PAUSE 1000
SEROUT Sdat, Baud+$8000, [noparse][[/noparse]"!SCRSP", ch, CR]
DEBUG "Servo ", DEC buff(0), " ", HEX2 buff(1), " :", HEX2 buff(2), CR
NEXT
RETURN
ch VAR Byte
pw VAR Word
ra VAR Byte
x VAR Byte
Buff VAR Byte(3)
Sdat CON 15
baud CON 396
Init:
ra = 15: ch = 12
DO
LOOP
WRservo:
FOR x = 0 TO 4
PAUSE 1000
NEXT
RETURN
The parameter you're questioning is the routine that SERIN branches to in the event of a PARITY ERROR. Here is the general format of the SERIN command:
SERIN Rpin {\Fpin}, Baudmode, {Plabel,} {Timeout, Tlabel,} [noparse][[/noparse]InputData]
Additional information about the SERIN command can be found in the PBASIC Reference Manual, or the PBASIC Help file.
Bruce Bates
When all else fails, try inserting a new battery.
Still looking for material on the PSC if any one knows of any
