I need advice...
CannibalRobotics
I need to track a couple of hundred data points (words) in what us old school guys would refer to as a "circular buffer".
I'm going to pull the trigger on either an SD memory or the USB data logger today.
Which is easiest to use with a prop?
Which takes up less prop memory to implement?
Which is the fastest?
Thanks ahead of time.
Jim-
Jim-
But, if you can go with a i2c fram/eeprom/flash (can be SPI) ... go for it, it will be simpler unless you need that a pc read/writes the data. In such a case you can always implement a PC interface via serial port.
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
