Does the BS2sx Float pins?
Question,
When the bs2sx microcontroller pin logic is "0" is it floating?
Is a pulldown resistor necessary for the bs2sx?
I am driving a NPN transistor as a switch for a relay with one of my pins and have a protection diode in the circuit but wonder if I should be using a pulldown resistor to ensure·the pin is grounded when it is not on.
How can there be·nothing? Nothing is something!
You generally need a pulldown (or pullup) resistor for the 3rd case, when the I/O pin is set to input mode (the default after a reset).
If you're using an NPN (or PNP) transistor, you probably don't need a pulldown (or pullup) resistor since bipolar transistors are current controlled and there's no current present when the I/O pin is set to input mode. If you're using an MOSFET, you will need a pulldown (or pullup) because these are voltage controlled and nearby voltages can induce a voltage in the high impedance input circuitry attached to the MOSFET causing it to conduct.
I'd always add a pulldown. It is lkely unnecessary at the power levels we're talking about, especially if the transistor is a robust type, but it's cheap insurance. I have seen adding one radically increase MTBF, years ago when I was designing medical lab equipment that had a lot of relays (and other solenoids) controlled by bipolars.
· -- Carl
What you say is interesting, though, I was not aware of these transient effects. And "always adding a pull-down" couldn't hurt.
Thanks for the information. I've always thought about the sorts of effects you mentioned as something for high power / high frequency / etc. applications and not for the garden variety "turn on a small relay" or "control a small DC motor". The effect on MTBF is something I hadn't expected.
Carl you made my brain hurt!!!!
I really wish I could find a way to go to electronics school.
I work nights 50 hours a week and have no time for school right now which really sucks a bucket of rusty nails.
Thanks for you guys generosity.
Post Edited (beazleybub) : 10/27/2008 3:29:30 PM GMT
· -- Carl, nn5i
