breadboard relay question
hey i have a small problem,
i recently baught some relays from radioshack for my fire alarm strobes and my smoke detector. The relays fit into my soldlerless breadboard but the keep falling out. Like they are not very tight, and somtimes they short out. Obviously when this happens to the smoke relay, the smoke no longer trips my control panel im making with my boe.
Is there anything (glue etc..) i can use to securly attach those relays instead of solder? (I tried, and I cannot solder well at all, also the pins on the relay are close together).
I dont care if the relays are permantantly attached, as long as they work.
chris.
chris.
Glue (hot glue or epoxy or silicone rubber) is fine for physically mounting things to other things, but soldering is the best way to make an electrical connection.
I'd probably plug the relay into the breadboard, then run a small bead of hot glue around the outside of it. The hot glue will adhere to the outside of the breadboard (and the relay) and not get forced into the contact holes where it will be difficult to impossible to remove later.
When I use pc relays on a breadboard for testing purposes I just simply wrap a rubber band around the breadboard and the relay and it seems to hold just fine and I do not get any shorts.
How can there be·nothing? Nothing is something!
