Propeller LED Pong...
A pretty fun project...
This is the 64x32 LED Matrix from Sure Electronics...
For the paddles, I got a couple of project boxes and 100K pots from Radio Shack.
The paddles are then read by a MCP3008 A/D circuit since I had one laying around.
Pictures,
Movie,
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
Pictures,
Movie,
Experience level:
/Bamse
(Next stop, sound effects?)
Actually, Pong is done and next stop is breakout on two of these boards on a 64x64 Matrix...
I ordered another LED board last week and it should be here in a week or so...
The propeller should be able to drive two of these boards in one cog since they can be chained...
Once I step up to 64x64, I will add sound...
Experience level:
/Bamse
Can I Play lol
Parallax posesses power beyond belief.
Believe in it.
- Stephen
Well done.
The reason I went with the MCP3008 is that I had one laying around (free sample) and there already was an object for it in the Propeller exchange...
I'm sure the Propeller can read the pots by itself...
I really only use 6 bits of the 10 available anyway...
Experience level:
/Bamse
I got two small ones in stead...
Experience level:
/Bamse
all you need now is a friend to play with!
someone who can live with your habit.
someone who can find joy in your creations even
don't we all have the same problem? lol
They way you powered all those LEDs
seems magical.
Keep up the excellent work and hope
to see more projects from you.
humanoido
This project is still being worked on and I have a playable 64x64 LED Pong using two of these boards...
I put a speaker on there and tried a few sound effects, guess what, the good old Square wave is a must for Pong to get that old school beep effect...
Experience level:
/Bamse
