Measureing frquency and vibration
I have the Hitachi H48C three axis accelerometer and it seems to be pretty easy to measure G forces. Has anyone tried to use it to measure vibration, if so how can you get it to measure and record a frequency? Also is there a way to both record and plot data from the accelerometer.
If you're looking at motor vibration, convert to RPM with:
RPM = Freq * 60 = 30,000rpm, then divide by the number of samples per wave you want (2 to 4)
Does that make sense?
The H48C is just a sensor, so it won't record/plot the data.· I've used the Parallax Oscilloscope to plot it, and used it to reduce vibration for imbalanced airplane propellers.
Jason
