Need Help - Propeller Beginner
Hi. I'm new to the forum and could use some help. I have just started learning the programing process for the Propeler (I have already learned the Basic Stamp) and have been running some small programs to the propeller though a serial connection using the schematic on the propeller information page on the Parallax website. I origanally had the propeller on a small soderless breadbord and the programmer on there too. All the programs ran fine untill I put the progaming module on a different breadboard because I ran out of space. I·finally moved the chip and every thing to a bigger breadboard.·When I plugged in the programer it said that the propeller chip was not detected. I checked the connections and everything seems fine, but it still isn't working. Is the Propeller itself not working? Is it the programmer? Should I order the Prop Plug to use insted? Please Help!
Check, if the propeller is correctly powering in the new board.
Sorry ... I mean if it has 3.3Vcc at power pin. and correctly grounded.
Regards.
Alberto.
Thank You For Reading! Please Respond!!!
I hope not. [noparse]:)[/noparse]
If previous you'd all working fine, try again with wires, should be something wrong..or simply the pchip die. (Although it is not commonly ...at least for me).
Regards.
Alberto.
Regards.
Alberto.
