stepper motor as clock drive
I have been knashing my teeth over a high powerd clock drive, as the arms are huge and heavy. I was wondering what you all thought of using a stepper motor or contiunius rotation servo as a drive? How would we set it, could it be made to be accurate enough to keep time?
-Paul
This isn't SX-related and probably ought to get moved to the Sandbox.
Parallax Engineering
One point of caution, the step size of your motor must match the time resolution. For example a 100 step motor won’t work very well for seconds because each second needs 1.67 steps. 1st needle movement points to 1.2 secs, next is to 1.8 secs, then 3 secs and so on.
You need to know when the needle is at Zero (probably 12:00 in your case) so you can eliminate any slip that may have occurred. In my case, it was easy, I just drove the needle against the Zero pin but with a clock you would probably use a minute magnet on the needle and a hall effect sensor at 12:00 (or where-ever you decide).
You can use 2 (or 3) steppers but as the shaft on one of the needle is a tube round the other shaft, you will probably need some sort of gear or belt drive anyway. Maybe you have some creative solution to this problem. If you do get one, please share it with us.
Kind Regards from the Dark and confusing continent – Africa
John Bond
