FSRW Errors
Every once in a while i find that FSRW creates a file on my SD card that I didn't want. Sometimes it has a file name off by a character or two, and other times the file name is actually a string that was meant to be appended to a differenct file. I am using the sdspiqasm block lever driver. I tried the others, but none of them work for me.
Any ideas?
Here's the code (with a lot cut out for clarity):
Any ideas?
OBJ ' 1 cog for main
uarts : "pcFullDuplexSerial4FC" ' 1 cog
phone : "MotorolaC168Iinterface" ' 0 cog
gpsParser : "GPS_IO_4P" ' 1 cog for parsing
thermometer : "OneWire" ' 1 cog
floatFormatter : "FloatString" ' 0 cogs
floatEngine : "FloatMath" ' 0 cogs
config : "config" ' 0 cogs
sdfat : "fsrw" ' 1 cog
PUB Main
temperatureCelcius := 0
config.Init(@configinfo)
uarts.Init
uarts.AddPort(0,config.GetPin(CONFIG#DEBUG_RX),config.GetPin(CONFIG#DEBUG_TX), UARTS#PINNOTUSED, UARTS#PINNOTUSED, UARTS#DEFAULTTHRESHOLD, UARTS#NOMODE,UARTS#BAUD19200)
uarts.AddPort(1,config.GetPin(CONFIG#PHONE_RX),config.GetPin(CONFIG#PHONE_TX), UARTS#PINNOTUSED,UARTS#PINNOTUSED,UARTS#DEFAULTTHRESHOLD, UARTS#NOMODE,UARTS#BAUD4800)
uarts.AddPort(2,config.GetPin(CONFIG#GPS_RX),config.GetPin(CONFIG#GPS_TX), UARTS#PINNOTUSED,UARTS#PINNOTUSED,UARTS#DEFAULTTHRESHOLD, UARTS#INVERTRX,UARTS#BAUD4800)
uarts.Start
gpsParser.start
phone.start
cognew(cameraTimer, @cameraStack)
cognew(logData, @loggerStack)
phone.setEchoOff
thermometer.start(THERMOMETER_DATA)
PUB logData | size
dira[noparse][[/noparse]16] := 1
sdfat.mount(SD_BASE_PIN)
repeat
outa[noparse][[/noparse]16] := 1
sdfat.popen(string("poslog.csv"), "a")
if (size := strsize(gpsParser.date)) > 0 AND size < 13
SDWrite(gpsParser.date)
sdfat.pputc(COMMA)
if (size := strsize(gpsParser.time)) > 0 AND size < 13
SDWRite(gpsParser.time)
sdfat.pputc(COMMA)
if (size := strsize(gpsParser.GPSAltitude)) > 0 AND size < 13
SDWrite(gpsParser.GPSAltitude)
sdfat.pputc(COMMA)
if (size := strsize(gpsParser.latitude)) > 0 AND size < 13
SDWrite(gpsParser.latitude)
sdfat.pputc(COMMA)
if (size := strsize(gpsParser.longitude)) > 0 AND size < 13
SDWrite(gpsParser.longitude)
sdfat.pputc(COMMA)
SDWrite(gpsParser.speed)
sdfat.pputc(CR)
sdfat.pclose
outa[noparse][[/noparse]16] := 0
waitcnt(clkfreq * 5 + cnt)
PUB SDwrite(strAddr ) ' Writes the string located at strAddr to the SD card
repeat strsize(strAddr) ' loop for each character in string
sdfat.pputc(byte[noparse][[/noparse]strAddr++]) ' Write the character to the file that's open
I'm working it very hard with ordinary file accesses mixed in with large numbers of block level operations.
If what you describe was happening in my code, I would initially be looking for coding errors that were
inadvertently creating files I didn't want. Over and above that I have found that it also pays to consider
such things as stack space as the possible source of such issues.
In general I find that it's better to write specifc code that tests any distinct object functionality, and which
will prove that the object is working as expected. In order to test functionality in this way the test shell
should be absolutely as short and as concise as possible. Then you will hopefully be able to determine
whether it's a hardware or software error, and much more easily.
If you do, things will almost certainly not work (the RC time constant will be sufficiently high that
your rise and fall times will stink and the card probably won't see the data).
Second, if you are getting broken file names, that's probably due to something somewhere
overwriting memory somewhere. I would:
1. Make sure you're using the latest fsrw (I updated it last month); there was a bug in there.
2. Are you plugging/unplugging the card while the prop is on? If you are, try not to do this
and see if it makes a difference.
3. Are you using multiple cogs? See if you can reproduce it using only a single cog.
Fundamentally, what you need to do is figure out how to make it happen *reliably*. Once you
can get the bug to occur reliably, then you can start eliminating code chunks and/or objects
until you reduce the problem to the minimum code. Then we can figure out what's wrong.
