Will this program work???
I am building a program that can turn 6 electro coils on and off at exact degrees of rotation.
(Called Ffire1 through Ffire6) I have the 6 fireing programs in 6 seperate cogs so that I know they will be fast enough, These·turn·the electro coils on and off.
(Called Windows) Then I have another cog that is controling the variables, at run time so I can tune or play with the timeing, that tell the coils at what degree and how many degrees to turn on and off. I did this because this program is really slow, but if it is in a cog seprate from the fireing cogs that is ok, cuz it works like I want it too.
(Called Reader) I'm still working on building this. but will mesure the leangth of time for one degree to rotate, all Fireing cogs will use this.
So I just wanted to know if I'm on a pretty good track, and that what I have written so far will work, Because this is my first propellor program.
I need to have at least one degree accuratce, half or quorter would be better.· Any thoughts or comments would be appreceated.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
OBJ
term : "tv_terminal"
kb : "keyboard"
VAR
long fire1 {how·many degrees·to wait before turning #1 on}
long fire2 {how many degrees before turning #2 on}
long fire3 {how many degrees before turning #3 on}
long fire4 {how many degrees before turning #4 on}
long fire5 {how many degrees before turning #5 on}
long fire6 {how many degrees before turning #6 on}
long win1 {how many degrees #1 is on}
long win2 {how many degrees #2 is on}
long win3 {how many degrees #3 is on}
long win4 {how many degrees #4 is on}
long win5 {how many degrees #5 is on}
long win6 {how many degrees #6 is on}
long begin················· {Use to Delay Ffire programs for about 8 seconds then start all 6 fireing cogs at the same moment}
long degree··············· {The leagth of time for 1 degree to rotate}
long read [noparse][[/noparse]20] {Stack space for Reader}
long f1 [noparse][[/noparse]20]··· {Stack space for Ffire1}
long f2 [noparse][[/noparse]20]··· {Stack space for Ffire2}
long f3 [noparse][[/noparse]20]··· {Stack space for Ffire3}
long f4 [noparse][[/noparse]20]··· {Stack space for Ffire4}
long f5 [noparse][[/noparse]20]··· {Stack space for Ffire5}
long f6 [noparse][[/noparse]20]··· {Stack space for Ffire6}
PUB Windows {cog #0}
cognew(Reader, @read)·· {Staring all cogs}
cognew(Ffire1, @f1)
cognew(Ffire2, @f2)
cognew(Ffire3, @f3)
cognew(Ffire4, @f4)
cognew(Ffire5, @f5)
cognew(Ffire6, @f6)
fire1 := degree '* ?··· {Starting Positions of each cogs turn on degree}
fire2 := degree '* ?···· I don't know these yet so I put ? marks instead
fire3 := degree '* ?
fire4 := degree '* ?
fire5 := degree '* ?
fire6 := degree '* ?
win1 := degree * 5·· {Starting·# of degrees each cog will be on before turning off}
win2 := degree * 5
win3 := degree * 5
win4 := degree * 5
win5 := degree * 5
win6 := degree * 5
term.start(12)·················································· {Start TV and Keyboard}
term.str(string("START FIREING WINDOWS",13))
kb.start(26,27)
begin := cnt···························· 'Starting point for Ffire cogs sync up
····························· I did this so I could be sure to have all 6 of my fireing programs start at the same time with the same point of begining
repeat···························· {Keyboard Controls for adjusting while program is running}
if kb.newkey == "q"
fire1 := fire1 + degree
elseif kb.newkey == "Q"
fire1 := fire1 - degree
elseif kb.newkey == "w"
fire2 := fire2 + degree
elseif kb.newkey == "W"
fire2 := fire2 - degree
elseif kb.newkey == "e"
fire3 := fire3 + degree
elseif kb.newkey == "E"
fire3 := fire3 - degree
elseif kb.newkey == "r"
fire4 := fire4 + degree
elseif kb.newkey == "R"
fire4 := fire4 - degree
elseif kb.newkey == "t"
fire5 := fire5 + degree
elseif kb.newkey == "T"
fire5 := fire5 - degree
elseif kb.newkey == "y"
fire6 := fire6 + degree
elseif kb.newkey == "Y"
fire6 := fire6 - degree
if kb.newkey == "z"
win1 := win1 + degree
elseif kb.newkey == "Z"
win1 := win1 - degree
elseif kb.newkey == "x"
win2 := win2 + degree
elseif kb.newkey == "X"
win2 := win2 - degree
elseif kb.newkey == "c"
win3 := win3 + degree
elseif kb.newkey == "C"
win3 := win3 - degree
elseif kb.newkey == "v"
win4 := win4 + degree
elseif kb.newkey == "V"
win4 := win4 - degree
elseif kb.newkey == "b"
win5 := win5 + degree
elseif kb.newkey == "B"
win5 := win5 - degree
elseif kb.newkey == "n"
win6 := win6 + degree
elseif kb.newkey == "N"
win6 := win6 - degree
term.dec (fire1)······························ {Displying Results on TV for tracking·on·and off·positions}
term.str(string(" "))
term.dec (fire2)
term.dec (fire3)
term.dec (fire4)
term.dec (fire5)
term.dec (fire6)
term.str(string(" ",13))
term.dec (win1)
term.dec (win2)
term.dec (win3)
term.dec (win4)
term.dec (win5)
term.dec (win6)
PUB Reader··································· {Measureing of time for one Degree to Rotate, cog #1}
'degree :=··········································· This is what I am trying to build right now
Pub Ffire1 | time0············································ {Running motor #1, cog #2}
waitcnt (begin := begin + 384_000_000)··············· 'wait to sync with other cogs, 8 seconds
time0 := cnt
outa[noparse][[/noparse]0] := 0
repeat
waitcnt(time0 += (degree * fire1))
outa[noparse][[/noparse]0] := 1
waitcnt(time0 += (degree * win1))
waitcnt(time0 += (degree * (360 - (fire1 + win1))))
Pub Ffire2 | time1···················································· {Running motor #2, cog #3}
waitcnt (begin := begin + 384_000_000)······················· 'wait to sync with other cogs, 8 seconds
time1 := cnt
outa := 0
repeat
waitcnt(time1 += (degree * fire2))
outa := 1
waitcnt(time1 += (degree * win2))
outa := 0
waitcnt(time1 += (degree * (360 - (fire2 + win2))))
Pub Ffire3 | time2······································································ {Running motor #3, cog #4}
waitcnt (begin := begin + 384_000_000)········································· 'wait to sync with other cogs, 8 seconds
time2 := cnt
outa := 0
repeat
waitcnt(time2 += (degree * fire3))
outa := 1
waitcnt(time2 += (degree * win3))
outa := 0
waitcnt(time2 += (degree * (360 - (fire3 + win3))))
Pub Ffire4 | time3······································································· {Running motor #4, cog #5}
waitcnt (begin := begin + 384_000_000)········································ 'wait to sync with other cogs, 8 seconds
time3 := cnt
outa := 0
repeat
waitcnt(time3 += (degree * fire4))
outa := 1
waitcnt(time3 += (degree * win4))
outa := 0
waitcnt(time3 += (degree * (360 - (fire4 + win4))))
Pub Ffire5 | time4························································· {Running motor #5, cog #6}
waitcnt (begin := begin + 384_000_000)···························· 'wait to sync with other cogs, 8 seconds
time4 := cnt
outa := 0
repeat
waitcnt(time4 += (degree * fire5))
outa := 1
waitcnt(time4 += (degree * win5))
outa := 0
waitcnt(time4 += (degree * (360 - (fire5 + win5))))
Pub Ffire6 | time5·························································· {Running motor #6, cog #7}
waitcnt (begin := begin + 384_000_000)····························· 'wait to sync with other cogs, 8 seconds
time5 := cnt
outa := 0
repeat
waitcnt(time5 += (degree * fire6))
outa := 1
waitcnt(time5 += (degree * win6))
outa := 0
waitcnt(time5 += (degree * (360 - (fire6 + win6))))
CON
OBJ
kb : "keyboard"
VAR
cognew(Ffire1, @f1)
cognew(Ffire2, @f2)
cognew(Ffire3, @f3)
cognew(Ffire4, @f4)
cognew(Ffire5, @f5)
cognew(Ffire6, @f6)
win2 := degree * 5
win3 := degree * 5
win4 := degree * 5
win5 := degree * 5
win6 := degree * 5
kb.start(26,27)
if kb.newkey == "q"
if kb.newkey == "z"
term.dec (fire2)
term.dec (fire3)
term.dec (fire4)
term.dec (fire5)
term.dec (fire6)
term.dec (win1)
term.dec (win2)
term.dec (win3)
term.dec (win4)
term.dec (win5)
term.dec (win6)
time0 := cnt
repeat
time1 := cnt
outa := 0
repeat
outa := 1
outa := 0
time2 := cnt
outa := 0
repeat
outa := 1
outa := 0
time3 := cnt
outa := 0
repeat
outa := 1
outa := 0
time4 := cnt
outa := 0
repeat
outa := 1
outa := 0
time5 := cnt
outa := 0
repeat
outa := 1
outa := 0
if this can works depends highly on the rpm that have to be controlled by this.
To make your code more readable use this little manual
attached to this posting
Its a pdf named .pdf.zip that this forumsoftware can handle it
@Parallax: From this forumsoftware I get more and more the impression is limited and NOT up to date
searchfunction: miserable
attachment-manager: rejects a lot of file types
go searching for a better software or make the company hurry up to improve it SUBSTANTIAL
best regards
Stefan
Post Edited (StefanL38) : 10/22/2008 8:28:47 PM GMT
