Need help with Counter PE lab — Parallax Forums
Tom PTom P Posts: 97
edited 2008-10-23 01:08 in Propeller 1
Propeller Heads:
I need help I am trying to work through the Counter-lab section on IR detect
I built the circuit on the protoboard and loaded the software into the the propeller and opened up hyperterminal to see the results but I see nothing. Not sure of the instructions below from the lab ?
What is PropellerCOM.ht?
Any help would be appreaciated
tom
? Make sure PropellerCOM.ht is open but disconnected.
? Load IrObjectDetection.spin into the Propeller chip.
? Connect PropellerCOM.
? The state should be 1 with no obstacles visible, or 0 when you place your hand in front of the
IR LED/receiver.
<subject line added by moderator>
Post Edited By Moderator (Paul Baker (Parallax)) : 10/22/2008 4:13:29 PM GMT
  • LeonLeon Posts: 7,620
    edited 2008-10-22 16:05
    It's a Hyperterminal file. Just double-click on it to run the program.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • edited 2008-10-22 23:45
    Hi Tom,
    You are probably working from v0.81. I just posted v1.0 and recommend updating. It's available from the PE Kit Labs page.
    http://forums.parallax.com/showthread.php?p=617192
    This lab eliminates HyperTerminal, which is no longer always free, and instead uses the Parallax Serial Terminal. It's got some additional material and full questions/exercises/projects and solutions.
    Andy
    Andy Lindsay
    Education Department
  • KeithEKeithE Posts: 957
    edited 2008-10-22 23:57
    Andy,
    Have any other labs been updated recently? (Besides the brand new ViewPort lab.)
    I was just going to go through a few of them.
    Keith
  • edited 2008-10-23 00:02
    Keith,
    Yes, the Objects lab was updated to use the Parallax Serial Terminal instead of HyperTerminal for Propeller <--> PC text communication. The Parallax Serial Terminal is easier to use, and free.
    I also just posted information on updates to the Counter Modules and Circuit Applications lab.
    The latest PE Kit Labs are always available from the Propeller Education Kit Labs page.
    Regards, Andy
    Andy Lindsay
    Post Edited (Andy Lindsay (Parallax)) : 10/23/2008 12:11:23 AM GMT
    edited 2008-10-23 00:13
    Tom P,
    The first thing that always comes to my mind, especially with an IR LED, or just LED's in general·is making sure that you have the correct polarity either on the IR LED itself or the Detector.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 10/23/2008 12:18:27 AM GMT
  • SRLMSRLM Posts: 5,045
    edited 2008-10-23 00:23
    I found out that I can see the IR LEDs on my digital camera. It helps to make sure that they're actually on...
  • edited 2008-10-23 01:08
    Tom P,
    Parallax Serial Terminal is in a folder in the v1.0 zip of the Counter Modules and Circuit Applications (Counters) lab. Instructions on using Parallax Serial Terminal are in the Objects lab starting on page 13.
    In a related thread, SRLM pointed out that there is an error in the IR detector schematic in Counters v0.8,·and that it has been corrected·in v1.0. So·please do·download the Counters v1.0 and double check your circuit.
    Andy
    Andy Lindsay
    Post Edited (Andy Lindsay (Parallax)) : 10/23/2008 2:26:54 AM GMT
