Wireless PC programme control
Hi ,
I plan to build a wireless remote that will control a programme running on a pc.So correct me if i'm wrong ..i'll use a basic stamp for the remote and a transmitter and on the pc another basic stamp chip with a reciever on it.With serial connection to the PC.Is this the correct setup?..
Then, on the PC you'll need to write a program which reads the serial port, and converts the read "serial data" into what you want the PC to do.
Since you can get an IR-Remote for $10 to $20, you'll save some money there.
Actually, what's different between "Play" and "Start"?
