switching ac lights — Parallax Forums
switching ac lights
MR SPARKYMR SPARKY Posts: 23
edited 2008-10-22 21:21 in BASIC Stamp
I am trying to switch ac lights with a BS2IC. I am using fagor FT0807MH4304 logic level triacs. I cant get the controler to turn the lights on and off. they stay on when computer is connected and off when computer not connected. Am I missing something in the circuit. please help.
I light up·everyones life!!!!!
    edited 2008-10-21 16:00
    Well, if you include your circuit we might be able to tell you...
    - Stephen
  • MR SPARKYMR SPARKY Posts: 23
    edited 2008-10-21 16:14
    i dont have any software to create the cicuit. what i did was connected L1 to MT1 and the load to MT2 the pin from BS2 to the gate through a 10k resister. i tryed to reverse MT1 and MT2. the light would only light with the computer connected to the controler.
    edited 2008-10-21 16:38
    i provided a link to the triac i am using
    http://www.alliedelec.com/Images/Products/Datasheets/BM/FAGOR/FAGOR_ACTIVES-AND-PASSIVES_3490148.PDF
    i have attached a file frome design works express.
    edited 2008-10-21 16:43
    if anyone knows where i can find software to design and test circuits it would be helpful.
    edited 2008-10-21 21:54
    MR SPARKY,
    You need to provide a galvanic isolation between the TRIAC and the driver circuitry. The situation you have is dangerous in that the circuit is completed through the connection on your computer.
    The "safe" way to do this is use a SSR (Solid State Relay) which has all of the necessary isolation.
    If you want to roll your own with the TRIAC you have, there is a missing component called an OPTO-Isolator that you need to include. See the link below for a description/example of using an OPTO_Isolator to drive a TRIAC.
    Note: The OPTO-Isolator itself should have a triac output.
    www.signindustry.com/electric/articles/2000-11_ALDORtriacexplainted.php3
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 10/21/2008 10:04:04 PM GMT
    edited 2008-10-22 16:41
    thank you beau schwabe. i found that out later on in my searching.
    edited 2008-10-22 16:49
    i see the diagram. but what size resistors should i use for my particular triac. how do i figure that out. what would be the best most afordable opto isolator be.
    MR SPARKY,
    The Opto-Isolator used in my previous post is a MOC3061.· The Datasheet below provides an example schematic.
    http://www.fairchildsemi.com/ds/MO%2FMOC3063-M.pdf
    DigiKey has them for·$1.12 here...
    http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&keywords=MOC3061&x=8&y=10
    Beau Schwabe
    IC Layout Engineer
