some smoke and a very ticked of teenager
ok, so funny thing, i was working on the last few bits of a school project that included a parallax ping sensor. i hooked it up to a 5v dc power source just as the front of the ping states. it went BOOOOM, and 2 of the orange things on the back exploded and spit out a big puff of smoke, i cried for a while and then wanted to know why it happened. i took out my voltmeter, and check the voltage at the source i plugged in the ping, i get 5.13ish volts, i know for an absolutely positivly so help me god that i hooked it up right, i dont know why this happened, has anyone here ever had this happen or know why it happened. i had droped it from about 10ft early in the night, could this have done it.
Pi Guy
Word to the wise...... ALWAYS check you psu for proper voltage before you hook it up. Had one labled 9VDC one time and it was putting out up to 23v and fried the scale we use for ups shipping at my work.
I hope that was a "typical rookie mistake", right?
Paul Baker
Can you post a picture of the sensor with the blown parts? If they are tantalum caps then yes, those can and will go out in flames if you accidentally reverse the polarity. Tantalum caps as well as polarized electrolytic caps can do this when the polarity is reversed. Tantalum usually seem to go up in a burst of flames for a moment while electrolytic caps usually explode in a loud bang. Anyone who has worked with electronics for any length of time usually runs into this at least once. I remember this happen with an electrolytic in High School electronics and have seen the Tantalum a few times since then.
You might be able to send in the sensor for repair. If it is just a couple of caps then as someone already suggested you might be able to just replace those parts to fix it.
Good luck,
Robert
