Need help!
Hello, I'm new here! I'm considering getting the propeller chip or two, but I do have a few questions though:
1. If I get the Demo board, what other part(s) does it require?
2. My plan is to make something sorta like a computer, only just not as advanced. I want to know if
its possible to hook up 2 propeller chips together, and have them communicate with eachother.
e.g, lets say i may want to make a video card for it, and let that do all the hard work and the
main processor just has to give the video card basic information, such as the resolution, and the
video card can receive that information and do all the hard work. is this possible?
3. How would I add RAM to it? What parts would i need?
4. When I read that the chips clock can be changed, what does it mean? overclocking it? or am I just comfused?
Help is appreciated.
Post Edited (Mr. Dr. Professor) : 10/20/2008 10:57:23 PM GMT
The creation of a mini computer from a Propeller is very possible.
Some of us were drawn to the Propeller because of this.
Check out these links.
PropDOS (and related software)
http://forums.parallax.com/showthread.php?p=683157
PropGFX (A Propeller addon video card {made from another Propeller})
www.propgfx.co.uk/forum/Blah.pl?b-PL/
Also, since you are new, you might appreciate this list..
www.warrantyvoid.us/projects.html
Welcome to the forums..
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
2) It's been done. Look at forum message threads regarding the Prop-GFX which is a Propeller-based graphics processor meant to be used with a separate Propeller or other microcontroller.
3) You can add additional serial EEPROM or RAM (or FRAM which behaves somewhat like both) easily. I2C-based memory is the easiest to add and there are several I/O drivers that can use it. Keep in mind that this memory DOES NOT extend the existing RAM or ROM. There's no way to do that. You can also add an SD card. All that requires is an SD card socket and optionally 4 pullup resistors. The I/O drivers for this are in the Propeller Object Exchange library. The SD card can be up to 2GB in size and uses a standard DOS/Windows FAT (FAT16) file system.
I2C memory can be added just by wiring the parts in parallel with the existing EEPROM although the Demo Board doesn't have provisions for accessing the device pins used for the existing EEPROM. You can use any other even/odd I/O pin pair with the existing drivers for another I2C bus.
4) The chip is not designed for "overclocking". It will work if you're careful about the power supply voltage (at the chip) and the operating temperature. The Propeller's datasheet has information on maximum system clock speeds vs. supply voltage and temperature. The system clock works at multiples of the crystal frequency used and that is configurable by a program. Read the Propeller manual for details of this and the internal RC clocks.
Post Edited (Mike Green) : 10/20/2008 11:16:22 PM GMT
I actually have that same Idea with the Operating system. I think its a pretty cool thing to do. as I've always wanted to do that with computers, but I have no idea how its done.
Oh, and mike, I dont know that much about electionics right now because im only 13, so could you please explain to me what an I2C is? Sorry,
I'm trying to learn as much as i can right now.
Post Edited (Mr. Dr. Professor) : 10/20/2008 11:26:25 PM GMT
In general if there is something that is completely new to you, a really good first place to check is wikipedia which generally does a good job at summerizing a subject. The I2C page is located here: http://en.wikipedia.org/wiki/I2c·
The information presented on that page is a lot more detail than you really need to know. There are several objects free for download from http://obex.parallax.com that make talking to an I2C chip quite easy (one of them was written by Mike Green, so the author would be able to help you here if you ran into problems (Sorry for volunteering you like that Mike)).
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/20/2008 11:39:06 PM GMT
I would highly recommend The Propeller Pro.Development Board.(It's Parallax part# 32111). It has everything Your lookin for. RCA "NSTC" video/DB-15 "VGA" video ,keyboard,mouse. An on board USB driver for programing (that hooks up to a host PC). A DB-9 RS232 AUX. serial jack. A large BreadBoard area to place that 2nd Propeller chip You mentioned.Plus a lot of other things.
But if Graphics are all Your lookin @,,Take A look @ the HYDRA.It has the added MEM. you spoke about and is geared toward video/gamming.
See ya in the next thread.
_____________________$WMc%__________________out_____________
But I would really recommend getting one from many of the major chip supply houses (Mouser, Digikey, Jameco, etc), You should look for one in a DIP package, since you can put it in a breadboard for easy wiring. The only other important thing to know is how big you want the memory, the one that comes with the demo board is 24LC512 (32K bytes (256K bits)). You should get as large as this or greater. If you type I2C eeprom in one of the companies search engine, it will take you to the chips they offer (I recommend Mouser for small orders since they don't charge a small order surcharge).
Paul Baker
Post Edited (Paul Baker (Parallax)) : 10/21/2008 12:10:32 AM GMT
lol sorry about that.
$WMc%, I took a look at the pro version before, but I thought it was kindof expensive.
And I think it has a little TOO much on it. its more than I need. And the HYDRA, I
originally was on xgamestation.com looking at that, but then I took a look at parallax,
and I liked the Prop demo board better.
Post Edited (Mr. Dr. Professor) : 10/21/2008 2:38:50 AM GMT
5. Whats· the max resolution the Propeller can support? I have a 1920x1200 monitor,
could I set the prop to use this resolution?
There is a 1600 x 1200 pixel driver downloadable from the Propeller Object Exchange. This requires 6 cogs for the video driver and uses about 16K for the display buffer. It's capable of displaying small areas of graphics which require further memory at roughly 4 pixels per byte.
Post Edited (Mike Green) : 10/21/2008 7:53:53 PM GMT
Yet another example of a use of a video card, I could have it display at a high resolution without it interfering with the
main processor.
http://mouser.com/Search/ProductDetail.aspx?qs=Z0HAwyWrFkw0HCxrN5WMtQ%3d%3d
Paul Baker
I have a 5400RPM 100GB laptop HDD, and I know I probably will not find 100GB worth of stuff for it, but i think it would make a
neat experiment.
Paul Baker
I wanted to get the 32KB one, but its all out. Maybe I should just connect a few· 16Kb chips together?
Thx Paul!
Edit:
Oh, and Mike, here are some pictures of what i was talking about:
The Screen
http://www.majhost.com/gallery/DarthToa/Computers/img_0695.jpg
The Cable
http://www.majhost.com/gallery/DarthToa/Computers/img_0694.jpg
As you can see, the cable looks like it has a lot of pins on
it. So If i do connect it, it looks pretty complicated.
Post Edited (Mr. Dr. Professor) : 10/23/2008 11:14:47 PM GMT
(almost impossible task) I think a couple people here have attempted it without success.
Better solution would be just to output to a standard VGA flatscreen.
OBC
You won't be able to boot from them, as they're accessed individually, not as a 'sum total'.· The Propeller boot loader wouldn't know to pull 1/2 the data from one and then the other.
SparkFun also sells the 32Kb I2C chip (http://www.sparkfun.com/commerce/product_info.php?products_id=525).· You're better off getting them from Mouser or another supplier, since they're cheaper: (http://www.mouser.com/Search/ProductDetail.aspx?qs=wJ05WdDZ4qSE4f7vrKy23Q%3d%3d).
Just do a Mouser search for I2C EEPROM.
Jason
I'm guessing that your probably right considering I have no idea what your talking about.
@ Jason
I'm not going to be booting from them, but using them as RAM.
Post Edited (Mr. Dr. Professor) : 10/23/2008 11:26:22 PM GMT
Using I2C EEPROM as RAM might not be such a good idea; limited write lifetime plus slow write times may get in the way there. FRAM would be better but might not be ideal, depends on the actual application.
It is possible to use a Propeller chip as a 32Kx8 I2C RAM but I'm not sure what the maximum bus speed / throughput would be.
Interfacing to an IDE Hard Disk isn't as bad as it could be nor necessarily I/O hungry if you use an 8-bit bus and forgo half the disk capacity and don't need to be compatible with any other file system. Perhaps the hardest part would be interfacing the 3V3 Propeller to what are usually 5V drives.
Stick to a VGA display. Stick to either an SD card for mass storage or something like the Vinculum with a USB memory stick. There's plenty of work and the associated learning starting from there.
Never mind the fact that if you get the timing wrong the things boil
(This is the reason that the X.Org nVidia, Intel and ATi graphics drivers ignore any custom frequency settings on laptop screens)
