info about Stamp PLC
Hello,
I am a graduate student. I am developing a controller-data logger system for my project. I am thinking about using a parallax stamp PLC for my system.
can any body kindly answer these questions?
1. the PLC has only 4 analog inputs. is there any way to increase them to at least 6?
2. I want to use the PLC as a data logger too. how much is its memory size?
3. is there any A/D converter module among Parallax products ? I mean something that can convert an analog signal from a sensor to a digital signal so that I can use a digital port for reading an analog sensor?
thank you very much,
PS: sorry about my last Post. I forgot the to write the subject
Similarly, you can multiplex the a/d channels or use a multichannel a/d chip. Linear Technologies makes a whole family that will work with Stamps. The standard one I use is a 12-bit 2-channel LTC1298.
Rather than the Stamp PLC, I'd recommend a Stamp chip (from experience I'd use a BS2sx or BS2px) and a Super Carrier board ( #27130).
Large-scale data storage on-chip is not too practical; use an external memory unit such as a VDrive which will let you store data in a USB thumb drive.
Cheers,
Tom Sisk
http://www.siskconsult.com
i am not very familiar with electronics. one of my friends has made me a a/d converter and amplifier. i can connect it to my basic stamp and read analog signals. the problem is that i need to have more ports for more analog sensors. the sensors are all the same.
your solutions are very general are very promising but i need a detailed circuit design and the program codes (just like parallax text books).
do you know where i can find this kind of information?
thank a lot,
Farsad
You can find this and the matching source files here: www.parallax.com/Store/Sensors/CustomKits/tabid/134/txtSearch/stampworks/List/1/ProductID/144/Default.aspx?SortField=ProductName%2cProductName.
i have made an a/d converter circuit for each of my sensors and i read them with shifin command. can I still use the expanded digital inputs as regular inputs? (i don't think so!) how should i write the code? do you have a sample program for reading the expanded analog inputs?
thank you much again,
Farsad
I recently used the 74HC165 circuits to give 20 additional inputs at the expense of 3 or 4 Stamp pins.
Sample programs are shown as well.
Cheers,
Tom Sisk
Unfortunately, the PLC, although nicely packaged for industrial control, is limited in how it can be expanded. The Stamp's digital inputs and outputs have protective isolators which make it difficult to use them as bidirectional I/O pins which you would need to attach most external ADCs. The optional built-in ADC, although it has 8 analog inputs, only uses 4 of them and there's no provision for using the other 4 without modifying the circuit board of the PLC.
Your duplicate post was removed. In the future please do not repost if you make a mistake. Instead click the pencil icon at the top right of the message and edit your post as necessary.
Parallax Engineering
