Multiple Propellers & one EEPROM
godzich
I might have an application where I need 8...16 propellers, all running the SAME program! All these MPU's are located within 15..20 cm on the same PC-board.
Therefore I wonder:
1. Would it be possible to use the same serial EEPROM for all the chips for bootloading?
2. If not - is there any other simple gimmick to ease the design (I would like to only have one serial port and only one eeprom, not a bunch of them)?
3. Im considering also using only one clock. I need complete sync between the propellers after the start (no drift). Distributing 5MHz about 20 cm is not probably too bad. Can one "master" propeller (with a xtal as the oscillator) feed the other 7 (maybe a buffer in between - or has the clk out enough power to drive clk_in on 7 other propellers)?
8 propellers booting the same code from the same EEPROM would be SO neat !!! Anyone that have been over this problem before???
I played with the idea that I delay the reset to the propellers, one by one, so that there is enougt time for the former one to load the contents from the eeprom, before the next propeller awakens. Would this work, and how long is the worst case delay I have to use between letting propellers out of the reset? Is the capacitive loading too much for 8 propellers to be parallelled this way to one eeprom? I did not find any data on what is the read bit rate during boot...
Christian
The future does not exist - we must invent it!
Therefore I wonder:
Christian
3) You can't use the clock pins for a source of a clock signal. They're not intended for any kind of external load. You would have to use an external clock circuit and that could have enough drive capability to drive 8 Propeller chips.
It would be possible to have 8 Propellers share an EEPROM as long as only one is accessing the EEPROM at a time. If the Propellers are connected so that they're held in reset until the previous one lets them out of reset, this could work. See the Propeller datasheet for boot times. It would be about 2.5 seconds for each.
There are much better devices than the Propeller for that sort of application, BTW.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 10/20/2008 2:48:27 PM GMT
You could very easily use a single reset and transmit line, having an individual receive line back from each propeller. There is no specific delays or interactivity in the transmit side of a loader.
Pull my finger!
It may be possible to get the hubs "synced" with a small margin of error.· Have ALL cogs listen for the sync signal, and then set a lock.· The one closest to the HUB window will win the race and obtain the lock.· Use this cog as "COG 0" and the rest in order accordingly.· I have not tested this, it's just an idea.
Updating the·software would be simple with this scheme because only the first·Prop would be involved in communication with the PC.· The rest would be held in reset by the pull-down resistor.
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Post Edited (Ken Peterson) : 10/20/2008 7:27:21 PM GMT
As soon as i switched power on the prop proto board, none of the leds would come on - i guess this is because one prop was clobbering the other one's signal on the eeprom's i2c lines so none would load the code properly. But if i shorted the reset pin to ground on my circuit prop, it would load right up and the led would light up.
so if you can sacrifice 1 io pin per prop, the simpliest would be to daisy-chain all your props, such way that as soon as one of them loads up, it'll pull down and up (to reset) the reset pin on the prop next to it, to propagate the "reset chain reaction" and let the next prop load up over the i2c line (i.e token passing). While having all props connected to the i2c bus (but i don't know if doing this kind of thing is within-spec).
don't make a complete circle though
hope this helps
That is EXACTLY what I did yesterday, without knowing about your post. I prepared a short application brief to explain in more detail the pros and cons of such a system, please find it attached here. It works wonderfully [noparse]:)[/noparse]
Christian
- Bjarne Stroustrup
That is exactly my intention. At least so that these "hardware coded" pins tells the propeller its position in the chain, not to necessarily selectively run alternative software (also possible), but to handle different data in some data streams throwed at them [noparse]:)[/noparse]
These propellers are actually connected via other pins as well, to form a chain or matrix of propellers, so that they can pass data within the array.
Additionally, you could use the already reserved ·EEPROM scl and sda lines for interchip communication (since all propellers are connected to them), based on the ID by the hardwired pins! As long as you do· not use sequences that trigger the EEPROM into life. Most ideally you could use the same·protocol as the EEPROM is using (but a different address), communicating with other propellers from one master·[noparse]:)[/noparse]
This above mentioned effort is unecessary if you have other pins to spare, but could be convenient in a tight pin budget design, such as mine.
Christian
One addition which may be useful is a wired-OR link or similar to the 'master Propeller' so it knows when they have all booted and can even determine how many have been booted.
The problem of sequential booting is that the boot time can become considerable. An alternative approach would be for the master to control resets and program each Propeller Chip's Eeprom in turn whenever a new program has been downloaded. That way boot time will be minimised but the master to slave interconnection will be more complicated. It would probably be best to have a separate bootload controller dedicated to the task rather than part of the running slave network.
Using a specially written PC Bootloader App it would be possible to implement this without having to have the bootload copying code downloaded into each slave.
For simplicity, godzich's daisy-chaiinng is the easiest approach.
I was shocked to learn that the boot time for 10 propellers can be half a minute, using this daisy chain configuration!
This might be prohibitive in some applications. But that scheme IS simple, have to admit. And we all know that "Simple IS beautiful..." I use that mantra often, especially when meeting new people. I often continue that phrase with the words"..., just look at me".
Christian
I don't know if this ever happened.
It does suggest to me that you could give each Prop in an array it's own EEPROM, they are not so expensive and they can also hold the Prop identification info. Load the EEPROMs with a little boot loader program which would then load up code that is "broadcast" over a single serial bus from a home made loader program on your PC.
You could probably end up programming the entire array in parallel faster than the current Prop tool does a single Prop.
With a bit of work on the loader protocol one could also support different programs for each Prop loaded sequentially.
Post Edited (heater) : 10/21/2008 6:40:23 PM GMT
· Your design pattern for daisy chaining multiple propeller chips off of a single EEPROM is excellent.
· This procedure works very well.· I am currently linking 5 propeller chips into a 40 processor toroidal vector topology·and I am able to load the same spin code on all 40 processors.· This is an experimental work in progress where most of the work involves the software around the PC client and host propeller. I expect that it should scale to 64 processors using a single power supply.
· I get a load time of 7.5 seconds for 5 propeller chips ( 1.5 seconds / propeller) after a reset from the 6th host propeller.· However, depending on the load of support chips the 5th processor sometimes takes an extra 5 seconds to load - It is the furthest from the EEPROM and probably signal degraded due to my breadboard capacitance.· I will update the site in a month or two when I get all the software and design worked out.
· Here are a couple photos of a test circuit with load/save circuitry partially wired for a·40 propeller processor array·running in·SIMD mode.
· So I am grateful for this piece of work·on propeller cluster design from you guys.
· /michael
What are you going to do with that?
lonesock
Piranha are people too.
If you want to load from a single eeprom and save pins by reusing 30, and 31 for i2c comunication. have 1 prop deactivate the eeproms enable pin then you don't need to worry about triggering the eeprom.
http://forums.parallax.com/showthread.php?p=661998
Of course my idea of enumeration was to have each prop increment a location in the eeprom before passing on control to the next prop. The last prop had to know it was the last prop and set this location back to zero for the next time. The easy way in this case is to put a pullup on it's reset control port so that before it would try to make it an output it would see a high rather than a low (from the next prop's pulldown).
*Peter*
*Peter*
If you do not have enough pins, then tie all the other props serial pins together to a pair of io pins on the first prop. Use a latch (74hc573). Each output will be connected to each ot the other props reset pins. The inputs will be connected to the first props pins (which may be subsequently used by the first prop, so in parallel with). The LE pin will be connected to a dedicated pin on the first prop.
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
My cruising website is: ·www.bluemagic.biz
http://forums.parallax.com/showthread.php?p=956909#post956909
/Michael O'Brien
