Just built another boebot -Same IR curse.
It is phenominal.· I just built my second boe-bot. This time, I am going to program it in PBASIC.· I was running some of the test programs and sure enough when I get to the IR program, I am having problems. Specifically, I get a 5 reading no matter what. Last time, with the propeller, I got a 9 no matter what. All I want to do is make sure that it doesn't fall off of the table or run into anything. This is so simple, but for me it has been a nightmare.
I KNOW that I must be doing something wrong. I have worked through the WAM book and all the way through robotics with the boebot.· I have followed well, except for when I got to IR.· I don't want to wire anything backwards and make the detector burn up like it did last time.
Everything else aside, though, I LIKE this little bot. I like the Board of Education and I like Parallax. I LOVE Pbasic. It is something that I understand better than ASM, SPIN and boebotBasic on the prop.· Not that the prop was bad, I am just not to that level yet.
I am using the documentation and software that came with the unit. I am not even altering anything.· I know how to follow schematics, I have been a Licensed and Certified Technician since 1971.
I am sure that I will figure it out. Just wanted to give some feedback that some people have mental blocks in certain areas. I guess IR is mine. I understand the principal and the concept. It just doesn't work when I apply them.
You need to figure out what you're doing wrong. The examples in the Robotics with the BoeBot and the IR Remote with the BoeBot do work. You can easily test the interference hypothesis by turning off the CFLs in your work room while you're testing your BoeBot and using a flashlight or portable incandescent lamp for illumination.
I will try what you suggested , mike.
One more thing. I swapped the resistors from 1 k to 2k to make it nearsited like the manual said. and it went from 5 to 1 readout all the time.
I turned on the lights and BANG! IR interference Detected.
So, I guess my other test was wrong. I am going to try everything with the lights out. All of my house is wired this way. :-(
I am going to have to figure out a way for the thing NOT to fall off of the table and NOT to run into things. I hate to go to a stupid contact switch. Maybe there is another kind of sensor that would work.
I now only use Parallax or Sharp IR detectors.
Also, I have the PING. But, even with Ping, the unit runs into things close to it. I was going PING for the distant and IR for the imediate sensor.
Do you think it could operate off of PING alone?
Oh, and I need to be able not to fall off of the table top.· That was my main reason for IR.
I can't understand this. EVERYONE has gotten past this stupid stage. What is diferent in this case?
Thanks for the replies.
But the Detector worked flawlessly every time.
Changed them over to some (parallax) ones I had on the arm of the bot - worked perfectly
Have since got some Sharp ISu160 which work the same as parallax ones.
Being in Australia it is hard to get parallax items especially $1 items as freight is worth more than the items.
I would be very reluctant to trust a single sensor type for something as important as edge detection. After all, if your sensor screws up, your poor 'bot falls off the table! I'd have at least two sensors, and one of them would be a "dumb switch". Switches aren't dumb, they are cheap, reliable and easy to implement. It's just risking too much to use IR alone, which is probably the least reliable. A combination of IR, a PING and a switch would be much, much safer.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
The "PING" has a Min. dist. that it can read.Since the "PING" would have to be·pointed down @ a hard angle this is not the best way to go.Have you tried useing a IR led and A IR Trany w/ some light baffles to keep outside light out....?????
I have used IR to detect a brake in the BEAM like A person or car passed through and area I wanted to monitor.Sun light was always a problem. I took a IR led "emitter" and pulsed it w/ a 1kHz tone.I then looked for a 1kHz signal on the IR "detector" and filtered every thing else out. I thought I came up w/ something Brillant,Only to find this is used by just about every Alarm Co. out there...You'll want to baffel the two so it see's the signal reflecked from the table
Drop a post reply if this fixed the problem
__________________________$WMc%______________________out_____________________
Post Edited ($WMc%) : 10/22/2008 12:57:42 AM GMT
Send a PWM signal out or "PULSOUT" to the IRled some were around 1kHz/Then use something like "PULSIN" or "INPUT" to see the Signal You sent out.Then some "IF" statments to look for this 1kHz signal.
If Your still drawin a blank,I'll be back tomrrow and I can send You some Sample Code. I'll have to dig it up!!...Just drop A PostReply
____________________________$WMc%_________________out______________
This worked for me:
····· 'Ir detector output connected to pin 10
····· IrLed············· PIN·········15
····· dropOff·········· VAR········Bit
····· FREQOUT IrLed,1,39000
····· dropOff=IN10
····· IF dropOff=1·THEN
····· ' take evasive action
····· ENDIF
··· Woops....I fixed the FREQOUT statement
Post Edited (Mikerocontroller) : 10/21/2008 3:44:18 AM GMT
This also frees up the Stamp to do other things.
You can use several approaches, but a simple 555 timer circuit can easily drive a few IR LEDs at the required frequency.
These can be on all the time, or pulsed. The detector only has to watch for reflections.
You can also get detectors for frequencies other than 38 kHz (such as 56 kHz), which will help with interference from fluorescent lamps.
You may want to Google for "IR proximity detector".
- Rick
RD, I will try the 555 circuit maybe, I have one lying around.
Thanks again!
I gess I wasn't clear enough on useing a ( IR LED ) and a ( IR TRANSISTER ) and not the 40kHz detector. Since the Flor.Lamps generate so much noise @ 40kHz (the type MovieMaker has),My intention was to get away from 40kHz w/ another Freq. and a hole new detector setup.Radio Shack keeps the IR led and IR tranny on the shelf and thier dirt cheap!!!!! I have had great success w/ this setup!!!
___________________________$WMc%_______________out______
