Robot Programs
Hi Guys,
········ I'm pretty much need help or someone to point me in the direction on how to·program the Basic Stamp 2 chip to learn or record data. I'm currently· building a robot to run through a micro mouse maze and programming it to learn to run the first run and having it learn the wrong turns. When it run the second time it should be able to run in the right path and not take any wrong turns after learning in the 1st run. Can someone point me in the direction on how to program the Basic Stamp 2 chip. Thanks.
0 = unused
1 = left
2 = forward
3 = right
4 = backward
Then, you'll end up with a list of choices: 242452321132131. The hard part will be detecting when you can make a choice.
humidity. While the modules may continue to function outside these ranges, it is not guaranteed or
recommended by Parallax, Inc.
