2 motor 4 pin control
Is there any way to control two motors fwd a rev both with just 4 pins instead of 8 looks like you could use a transistor as a switch to bring the low side to vss
my bridge uses 9ma so the vdd needs to be a lite load not more then 5ma.
Post Edited (be80be) : 10/16/2008 11:49:35 PM GMT
I don't know what you mean by lite load for vss. Vss is ground and is a reference point for logic and power supply.
John Abshier
i can bring its pin 2 low and just use 1 pin for fwd and 1 pin for rev on motor 1 and the same for motor 2. inverter could i not add a npn coming from vss that is also turned on by pin 1 to make pin 2
low my motor are low ma 120 or so. sorry about the vss its vdd i have to switch vss was what i was thinking.
Post Edited (be80be) : 10/16/2008 11:52:19 PM GMT
- Stephen
but thy need 4 pins each
Post Edited (be80be) : 10/17/2008 4:03:47 PM GMT
