Whats the best way to send a signal down 60' of wire? — Parallax Forums
GICU812GICU812 Posts: 289
edited 2008-10-16 12:30 in General Discussion
I have a device, it has 2 pins, and 2 signals (its a garage door opener for what its worth.
There is approxamately 16 volts when the circuit is working, but if you remove the switch module, its 22v, so I need to be able to cope with up to 25v
From taking apart the switch, Ive determined how it sees the diffrent signals.
Signal A: Short pin 1 to pin 2
Signal B: Connect pin 1 and 2 with a 1uf cap
I have a BS2 about 60' (by the wire) away. What is the best way to send a signal?
I was thinking of having 2 relays at the opener, one for each signal, then two PNP transistors to fire the relays.
I guess my question is, where should I have the transistors, at the opener, or at the stamp?
It would be one less wire to use if I had them at the stamp, and I think the stronger 12 volt signal (relay activation signal) would travel better than the 5v logic signal.
Or am I going about this all wrong with relays, would you reccomed just using transistors instead?
Im assuming the 1uf cap just allows power to flow for a brief instant, so could I just use one relay\circuit and pulse it briefly to immitate that, or am I thinking wrong?
  • Lab RatLab Rat Posts: 289
    edited 2008-10-16 10:12
    i would imagine shielded cable
    or twisted pair but i think twisted pair works the best
    Parallax posesses power beyond belief.
    Believe in it.
    I would say a twisted pair with RS-422/485 drivers, but RS-232 will work on 60' at slower baud rates. The main thing about RS-422/485 is that the driver transcievers are easier to wire than a MAX232 chip and run a lot cleaner data stream if you are actually sending data.
    If you just want to toggle a 25v line on and off, that is a different animal. To handle the 25V at the end of the line, use a rely to isolate it from your microprocessor. Relays always isolate a jump in voltage or a change from DC to AC, so they certainly are a good choice. Transistors or optoisolators may seem more 'high tech', but at times they just don't work at well.
    It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
    Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
