Interfacing Memkey 4*4 Keypad and BS2
I need help sending a High Voltage to pin 12 when Button 1 is pressed on the Keypad.
Connections
Memkey························· BS2
VDD··Connected·with······· VDD
GND··Connected·with······· GND
TM····Connected·with······· P15
·FM···Connected·with········ P14
KEY··Connected·with·········P13
K0
K1
K2
K3
K4
K5
K6
K7
Row0
Row1
Row2
Row3
Col0
Col1
Col2
Col3
Connections
K0
K1
K2
K3
K4
K5
K6
K7
Row0
Row1
Row2
Row3
Col0
Col1
Col2
Col3
Parallax posesses power beyond belief.
Believe in it.
Believe in it.
Believe in it.
··· I have used the MEMKey w/ great succ.s w/ the BS2...Checkout the super short progarm I attch.
·································································· $WMc%________out
2) can you help me send a High voltge to any pin I want.
···· Here's the MOD. I still don't know for sure what Matrix Your useing But I think this will work if the other program worked.
··· ALL BALLED UP,·I sent the wrong·file;I have attch. the rite one
······························· _____________$WMc%______out__
Post Edited ($WMc%) : 10/16/2008 2:40:14 AM GMT
MAIN
· Main:
··· 'call appropriate routines in the proper sequence
··GOTO Main
SUBROUTINES
·FLOW_SWITCH1 :
·· SEROUT 1, 32, [noparse][[/noparse]"WARNING!! Container A is empty" ]
·· RETURN
·FLOW_SWITCH2 :
··· SEROUT 1, 32, [noparse][[/noparse]"WARNING!!Container B is empty" ]
··· RETURN·
Post Edited (Mikerocontroller) : 11/20/2008 8:50:10 AM GMT
