Is it ok to solder a 40-pin DIP directly
Most of the time I use sockets, but I have something I'm going to make alot of and I need to keep costs down.· Is there any issue with soldering a 40-pin dip propeller directly to a pcb?
The protoboard and other they work thus. Where there are problems is in microcontroladores that need programming in parallel in case to need re-programming, but the Propeller uses an serial port.
Joel-
