serial communication
I'm having troubles with the serial·communication from a stamp1 to· a desk top computor. Is there anyone out
there that has done this before. It seems like no data is being sent or recieved. any help would be helpfull
readers
readers
If you are trying to use the programming port for input and output as you can on a BS-2, that won't work on a BS-1. See the following note from the PBASIC Help file, or PBASIC Reference manual, regarding SERIN and SEROUT:
"NOTE: ... The range of the Tpin argument on the BS1 is 0 - 7."
You MUST use one of the regular pin ports (0-7) for I/O. You can use the programming port for DEBUG output, but please be aware that the format of the DEBUG output is also different between the BS-1 and BS-2. DEBUGIN is NOT supported for the BS-1.
Bruce Bates
When all else fails, try inserting a new battery.
Post Edited (Bruce Bates) : 10/15/2008 8:18:52 AM GMT
I found out about the programming port. I'm useing pin 7 as serial in and pin 6 as serial out. I'm useing Vbasic as the program that talks to the stamp1 and as pf now no communication betwen them. Dose Vbasic need the hand shake?
Thank you
readers
·No i'm not useing programming port as serial port. I used pin 6 as serout and pin 7 as serin with no luck.
·I used Vbasic as the program to talk to the stamp1.
Any ideas would be helpfull.
Thank You
readers
You'll have to post your VBasic program to get any specific suggestions. Systems like VBasic don't normally require the hand shaking lines because they're not always present. It all depends on how your program references the serial I/O routines in VBasic.
This is the visual basic code I am using for serial communication to the bs1. Please let me know if this should work, or if I need more code.
·MSComm1.CommPort = 1
·MSComm1.PortOpen = True
·MSComm1.Settings = "2400,n,8,1"
·MSComm1.Output = "0"
·MSComm1.PortOpen = False
Thank you,
readers
