Digital to Analog Converter that will convert a range of -5 to +5 volts DC
I would like to interface an Analog Gyro to my BS2.· The outputs of the Gyros can be a positive or negaive DC voltage depending on the direciton of angular acceleration.·
I am thinking that I should use an analog to digital converter to interface with the BS2.· Is this the best method?
I have looked at some of the ADC sold by Parallax and the specs all say 0 to 5 volts, will these work?
Any help would be appreciated.
·Link to Gyros.
·http://media.digikey.com/pdf/Data%20Sheets/Analog%20Devices%20PDFs/ADXRS401.pdf
Post Edited (dodger) : 10/17/2008 11:56:38 PM GMT
·Link to Gyros.
I'm on the same band wagon as Mr.Pilgrim;need a little more info. on the Gyros.If you don't have any, Can you split the common conection to make two 0 to 5+ signals???...You could also look @ it as a 0 to 10 volt singnal + or - !!!!!
$WMc%___________out__
· http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/max1270.pdf
···· Darlene
········ I got your PM and I looked @ the link.· I thought You where talking about motor drivin gyros. I've never worked w/ the soild state model You have. The Doc. in the link refered to "CORIOLIS FORCE". I have worked w/ a few Coriolis Meters in fluid proccess. You may find some code snippets in this search.....Try lookin in LimeSlurry or Juice (like orange or grape)
·· P.S.· Have You looked @ the Hitachi HM55B compass Module (#29123)or H48C#(28026) TRI-Axis Accelerometer?. Memsic also has A Dual-Axis Ver. Parallax p# (28017)....All of these have some sample code to get started w/, And will do the same thing A gyro does
·············································· $WMc%______out________________
-- Carl
· -- Carl, nn5i
