Boe-Bot Robot with new Ultrafire Rechargeable 3.7V 900mAh 14500 Lithium Battery
Boe-Bot Robot with new Ultrafire Rechargeable 3.7V 900mAh 14500 Lithium Battery.
Ultrafire 3.7V 900mAh 14500 Lithium Battery Rechargeable·is same AA battery cell size.
Boe-Bot Robot AA Battery Holder· is up to 6 Volt for four Standard battery 1.5V is waste money.
4x 14500 Lithium Battery and total 14.8Volt and down to 5V in Board of Education
Notice: Ultrafire 3.7V 900mAh 14500 Lithium Battery Rechargeable is required purchase Ultrafire 3.7V chargeable unit at Hong Kong eBay for Ultrafire Flashlight Torch selling.
Anyone interest
Anyone interest
I think you're better off with a 5 cell NiMH battery pack and 2300mAh or 2500mAh AA cells which are readily available. 4 of these can fit in the normal battery holder and you can add a single cell holder from RadioShack or Parallax which is glued to the top of the aluminum platform over the skid ball. Although fast chargers made for NiMH batteries are best, you can charge the 5 cell pack just using a current limiting resistor to provide a maximum charge current of 1/10 capacity (or about 230mA) and charging for 12 to 16 hours.
That is probably why they are called "Ultra Fire" and a good reason to avoid them.
There are some advantages to the Lithium packs but when you factor in how dangerous they can be (anyone remember the laptop recalls or exploding cell phones) it just doesn't seem to be a good choice for Hobby projects. As I recall safely charging them is a bit tricky as well.
Robert
