24v hb-25?
I have a large and powerful 24v electric scooter motor that I would like to use with the HB-25. The only problem is the voltage. The motor is designed to run at 24v, but the HB-25 absolute maximum voltage is 16v. Will Parallax make a 24v HB-25, or is the only solution to run it at 12v? Possibly even with a lower current rating (15-20 amps)?
I am 1011, so be surprised!
Advertisement sponsored by dfletch:
Come and join us on the Propeller IRC channel for fast and easy help!
Channel: #propeller
Server: irc.freenode.net or freenode.net
If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
Channel: #propeller
http://www.parallax.com/Store/Accessories/MotorServoControllers/tabid/160/CategoryID/35/List/0/Level/a/ProductID/66/Default.aspx?SortField=ProductName%2cProductName
The difference between it and the HB-25 is it can't handle as much current but can run on 30 volts, plenty for your scooter motor.
Pi Guy
Channel: #propeller
·24 volt versions from $8.50 to $30, up to 30 amps. One has reverse.
