Sensiron + Propeller
Hello all,
After working with the sensiron temperature/humidity sensor all last night, I finally get it to output something. Onle problem is, something is wrong, and I don't know what it is.
Here's a couple of links that·make it easier·to understand where I'm coming from:
http://www.parallax.com/Portals/0/Downloads/docs/prod/datast/shtx.pdf·- Data sheet for sensiron
http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/SensirionDocs.pdf·- BASIC Stamp code for sensiron
Here is the function that I'm using to read the data:
Note that the dataHigh function sets the data pin to input, rather than forcing it high (supposed to let a pull-up resistor push it high)
The main problems that I am having are these:
The temperature (a 14 bit value) is output as two consecutive bytes. So, I want to read the first byte into the first half of temptemp (a word), and the second byte into the last half of temptemp. Am I using the BYTE command correctly? Its syntax is symbol.BYTE<[noparse][[/noparse]offset]>.
Secondly, when I actually have the value, I don't know if I'm converting it correctly. The formula (from the sensiron datasheet) is d1 + d2 • SOT, where d1 is -40, d2 is 0.01, and SOT is the read temperature. Here is the code I'm using to convert:
From the BASIC code sample, it gave this formula:
Where soT is the read remperature. It also noted that the·conversion factors·were multiplied by 10 to give tenths of degrees.
I'm attaching the propeller code, since I'm sure it would help to see everything in context. Note that there is a lot of commented out code, I was using that before I switched to using BS2_Functions (and it didn't work until I switched).
Thanks for your time, and I hope I made some sense.
PUB read(sendByte)
temptemp := 0
dataHigh 'Sends an "incoming transmission" message to the sensiron
clkLow
waitcnt(CLKFREQ / 100 + CNT)
clkHigh
dataLow
clkLow
clkHigh
dataHigh
clkLow
BS2.SHIFTOUT(DATAPIN,CLKPIN,sendByte,BS2#MSBFIRST,8) 'send a command to the sensiron
dataHigh 'Let go of data pin
clkHigh
if (ina[noparse][[/noparse]DATAPIN] == 0)
clkLow
REPEAT UNTIL (ina[noparse][[/noparse]DATAPIN] == 0)
waitcnt(CLKFREQ / 100 + CNT) 'Wait until datapin is pulled low, check every 10 ms
temptemp.BYTE[noparse][[/noparse]1] := BS2.SHIFTIN(DATAPIN,CLKPIN,BS2#MSBPRE,8)
BS2.SHIFTOUT(DATAPIN,CLKPIN,0,BS2#LSBFIRST,1)
temptemp.BYTE[noparse][[/noparse]0] := BS2.SHIFTIN(DATAPIN,CLKPIN,BS2#MSBPRE,8)
dataHigh
temptemp := calibrateTemp(temptemp)
Result := temptemp
PUB calibrateTemp(given) Result := given ** 0.01 - 40
tC = soT ** $1999 - 400
zip
31K
I donwloaded your ZIP-File and tried to compile it. But several errors occurred.
So I guess that the zipped code is not that one that you compiled or that you used for your latest tests.
Is this right ? Did your code compile ?
I think it will be good to post a zip-file that wil compile. After Uploading make an ultimative check by downloading this zipfile to a new tempfolder
load it from there and try to compile it.
edit: as I took a closer look: there are so many syntaxerrors. Please attach code that does compile.
best regards
Stefan
Post Edited (StefanL38) : 10/12/2008 5:39:59 PM GMT
Sorry, I see what I did wrong. I thought the compiler saved the file every time I compiled. I saved the file this time, and I'm attaching it to this post.
@Tim
Awesome, I didn't know there was an object for this. I will definitely take a look at it.
