Stamp Not Found but with details...
Hello,
I purchased the Serial Discovery Kit bundled with the USB-Serial item.· The whole thing sat in a box for atleast a year.· Well, I finally fired it up and the stamp was not found (Loopback and Echo were yes).· I went through the posts here and did not find an answer.· I got a homework board at radio shack.· Plug it in (usb-serial and board) and the stamp was found.· Here are the vitals of the BOE:
Board of Education Rev C
USBto232 Rev B
BS2 Rev G
Latest Drivers 2.4.6.0 on USB Serial Port and Serial Converted properties
Fresh 9 volt Battery
BS2 Well Seated
Did a little voltage messurement on the Sout pin after "Identify Command" and the voltage fluctuated.· Not fluent with a scope so I can't tell you what it sent.
So, unless the rubber feet are causing a short, I am at a loss.
What is next?
USBto232 Rev B
BS2 Rev G
BS2 Well Seated
What is next?
I`m not prejudice I hate everyone equally
