Magnetic Screwdrivers
Ugha
In computer repair, magnetic screwdrivers have always been a major no-no.
When working with other electronics (namely various ICs and the BS2) how
"bad" are magnetic screwdrivers?
Should they be avoided at all cost or only around a specific kind of device?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
To answer the original query, in most cases magnets and electronics get along just fine. If they didn't, things like servos, relays, and fan motors would have to have magnetic shielding around them just to operate in the proximity of electronic circuitry. There are exceptions, though. For example, some compass modules can suffer permanent damage if subjected to a too-strong magnetic field. The reason magnets are a no-no around computers is because of magnetic media, such as floppy disks and hard disk drives, whose contents can be compromised by magnetic fields. In the same vein, FRAM chips might also be sensitive to such fields, although that's mere speculation on my part.
For most electronic components the magnetism will not be noticed.
Might have a problem tweaking tuned circuits with coils but then even non-magnetized screwdrivers (containing iron) will do that. Use plastic.
Of course magnet sensors will sense.
According to the FRAM manufactures FRAMS are not affected by external magnetic fields.
Parallax posesses power beyond belief.
Believe in it.
